Author Topic: Will Unimog axles fit an '85?  (Read 3120 times)
1985ToyotaForLife
  • Member since Jan '04
  • I will own my 1985 until I die
« on: Jan 17, 2004, 01:08:34 PM »
I'm just curious here, will unimog axles fit under a Toyota 4x4? are they wide enough? The track width is 61". I think it would be pretty sick, portal hubs, up to 7.08:1 gears and they are very strong, and the diff's on the correct side. Would it work to drop one in a toy?
D.
Money is the only thing that keeps me from my dreams.
1985ToyotaForLife [OP]
Re:Will Unimog axles fit an '85?
« Reply #1 on: Jan 17, 2004, 01:09:27 PM »
Oh yea, forgot to mention cable actuated lockers in front and rear unimog axles, these can be swapped to run off an electric solenoid too.
YotaYota
  • Turtle Points: 12
  • Male Posts: 182
  • Member since Dec '03
  • Cuttin.....Weldin.....Grindin.....
« Reply #2 on: Jan 17, 2004, 06:44:29 PM »
Rear steer would be cool, killer axels has them for 1100 a pop, dont forget about convertin the tourqe tubes and get disk brakes.
Thumper
  • Turtle Points: 63
« Reply #3 on: Jan 17, 2004, 09:19:38 PM »
Hey man that would be a sweet axel too put under a toyota. :thumbs:
Anything will fit under a toyota truck if u have the will and the knowhow too put it under there. Ohh ya and a big enough hammer :_order: and fire :flamer:.
Me and a friend are fixing too swap in a set of 2 1/2 ton rockwells under his toyota so if those will fit i know unimog axels will fit.
Good luck on ur project
adam
YotaYota
  • Turtle Points: 12
  • Male Posts: 182
« Reply #4 on: Jan 18, 2004, 05:26:15 AM »
Hey Thumper, Can you say unsprung weight ???
How are you narrowing them, Hub Flip or gonna cut the castin and run 2 short shafts ??
Rockcrawlintoy
  • 4 doors for more whores
  • Turtle Points: 2147
  • Male Posts: 2,339
  • RIP Kyle
    • Buy me a soda
« Reply #5 on: Jan 19, 2004, 09:34:36 AM »
what mog ax;es are ypu using. 404s are on the wrong side as far as the diff goes. and they have a track width of 69 inches. my buddy has a set on his chevy that he is building and they are $$$$$$$$$$$$$ to build. wheel hubs for one axle is 650 bucks plus you got to get the rotors and calipers. oh yeah the hub bolt is torqued on at over 700 ft lbs. other than that they will fit. ohh yeah dont forget obout the suspension.
Drew
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
Thumper
  • Turtle Points: 63
« Reply #6 on: Jan 19, 2004, 12:20:05 PM »
why cut them down just gonna run them like they are except put disk brake's on them.
« Reply #7 on: Jan 19, 2004, 12:48:42 PM »
http://www.xtremeaxle.com/
Correct side diff, cable lockers, choice of gears, and disc brakes...
They are some cash, but its worth it.
Last post Jun 27, 2004, 07:19:01 PM
by yotaboy79
Tractor axles/Unimog axles
Last post Feb 20, 2005, 03:59:59 PM
by UNBREAKABLE
Last post May 06, 2005, 03:19:55 AM
by flyin ryan
Last post Apr 08, 2015, 10:38:36 PM
by Poorboyz
Last post Apr 03, 2017, 12:10:29 PM
by chriscorpus
