New to the board, from NC
Started by 1985ToyotaForLife, January 17, 2004, 12:41:25 PM
1985ToyotaForLife
Hey, my name is Daniel, I got a 1985 Toyota 4x4 that my dad bought brand new in feb. '85 and we've owned it ever since, it has around 5 inches of lift from springs/shackles, blown 22r carb'd, got the 350 sitting here waiting for money for adapters, its about to have a 3 inch body lift, and i'm most likely going to run 39 inch IROKs. Most likely blow my new transmission up with the 350 and those tires as well...
I'm also from NC in the capitol area, and I'm in college.
Lookin forward to gettin to know some of you.
D.
Money is the only thing that keeps me from my dreams.
Marlin
Welcome Daniel-not bad being born into the world of Toyota :beerchug:
Marlin
84runner
Welcome Daniel put your pic in readers rides and keep us posted on the work
