Electrical Wiring on 82
Started by 82rustbeast, September 09, 2006, 02:21:13 AM
82rustbeast
I bought this truck two weeks ago,it's an 82. I bought a battery, hooked up the wire to the coil to get it to start. It idles roughly but i'm working on it. But here's the REAL question.
It's a wiring nightmare. The The A.C., heater, stereo, and voltimeter and oil pressure guages r gone. I have misc wires everywhere. Seems like every light has a short. When I hook up the battery. The back up lights automatically turn on, so i pulled the fuse. then when i start it, the 4WD light brightens when i accelerate and flickers when i let off the gas. So how hard would it be to rewire pretty much everything. It's federal emissions 22R 4sp. Or is there someone who offers new wiring harneses for 1st gen toys. if not how about good used ones? Please help me with anything you can. I'll get up pics tomorrow morning.
stressdaninjalo
Hey there bud,
I'm new with toyota trucks but I have done many restorations from absolutly nothing. Laying out every single wire in a car. Since I found this painless wire harness I've newer fooled with anything else. Go to this link:
http://www.kwikwire.com/wh_22.html
and buy this:
The Kwik Wire 22 Harness includes:
High / Low Beam
Parking Lights
Gauge Power / Interior / Dash Lights
Turn Signal / Hazard Lights
Brake Lights
Horn / Cooling Fan Circuit
Ignition/Coil/Distributor
Starter Circuit
Charging / Alternator Circuit
Wipers
Fuel Pump
Radio / Accessory (Constant Hot)
Radio / Accessory (Ignition Hot)
AC/Heat Power & Fan
Pre-wired Neutral safety
Power Antenna
Power Windows
Power Door Locks
Cruise Control
Cigarette Lighter
(2) Auxiliary Connections
50 amp Maxi fused circuit for (instead of fusible link)
   Starter / Ignition
The power wires for the gauges should be plenty. If not you could always slice a gauge wire and use on 2 gauges.
If you have intentions on a fuel injected setup the also get this:
http://www.kwikwire.com/wh_TPI.html
Since your doing a wire for wire build check out this site too:
http://www.dakotadigital.com/index.cfm/page/ptype=results/category_id=59/home_id=59/mode=cat/cat59.htm
Get some "modern" upgrades for your ride. The 22 Circuit setup will have everything you need to wire your car plus plenty of room to grow for power options/ accessories later on!
Other notations:
The Difference Between Kwik Wire and The Other Guy
All wires in the block are crimped and hand soldered
Fuse blocks are compact and easy to mount
All wire is GM color coded and marked every 6"
All wire is GXL (heat resistant, oil resistant, gas resistant, water resistant, and crack resistant
Each harness is equipped with a coil kill switch
Each harness includes horn relay, turn signal flasher, hazard flasher and also a Maxi fuse to protect the unit
Each fuse panel has a brusher stainless cover with a fuse diagram on the reverse side
Each harness kit includes GM Column for the ignition and late and early model plugs for the turn signal
2 Headlight plugs included in the kits
All harnesses have ATO/ATC (Standard ΒΌ" blade fuses) no mini fuse here
Complete instruction book with easy to read diagrams.
100% toll free tech support line
100%  guaranteed
