CHECK OUT WHAT SHOWED UP @ THE SHOP TODAY.
Started by iNfErNaL, September 07, 2006, 10:37:27 PM
iNfErNaL
Fred Williams brought the UA FJ back to the shop today to do some cleaning up on it...Gettin' it ready for the Off-Road Expo in October.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
Duffil
Looks good, but like it won't have much compression travel??
BTW, saw it in the P4WOR.  Nice job on the sledge! :greengrin:
iNfErNaL
  :driving:
blackdiamond
boggerunner
Wermz84
That's the first one I've seen that I really like..   what kind of solid front axle is under that?
:thumbs:
I like to Drive!
Wermz84
I like to Drive!
boggerunner
Wermz84
I like to Drive!
boggerunner
how come in the last pic, the rim looks bent? the front pass rim?
BUDDERS
WOW, you have a better eye than I do.  I had to look at it twice to see what you are talking about, but it doesn't look right around the center ring of the rim  :headscratch:
boggerunner
must be in the design cause if the aluminum rim was bent thet much it would break, but i have bad eyes, just attention to detail
iNfErNaL
Quote from: boggerunner on September 09, 2006, 10:59:21 AM
Actually it is bent.I put those beadlocks together and when I was torqueing them they were starting to tweak.Then they went out on this trip and got smashed all to hell.
iNfErNaL
Quote from: Wermz84 on September 08, 2006, 08:23:15 AM
:thumbs:
Dynatrac Pro-Rock 60s front and rear.
