80 pickup on to a 85 4-runner fram need help
Started by crazymoritz97, August 22, 2006, 12:54:30 AM
crazymoritz97
hey guys & gals i need  some help big time I have a 80toyota truck with a 20r and i have a 85 4-runner from with engine the part that i need help with is the cab off the truck is 1and a half short then the 4-runner fram is what should i do to put on the cab please help me with info
frommoritz97
Chris g Moritz
:headscratch:   you want to put the cab of the 80 on the 4runner frame :dunno:
i'm thinking you will have to take the cab mounts off the 80 frame and weld them to the runner frame,  or make some mounts cause i dont think it will bolt on
Hottrod81
Why are you doing this mod?  You can find other truck frames out there and the wheelbases between the two, providing the truck is a shortbed, is nearly identical.
