2WD high - 4WD low one movement mod?
Started by rrick, August 21, 2006, 10:31:13 AM
rrick
Can i modify myshifter to go from 2 high to 4 low with one click? I really have never used 4 high with a front auto locker.
Tread Lightly: Combine Trips, Maintain Your Engine, Promptly Repair All Fluid Leaks, Drive Slower And Minimize Rapid Acceleration, Monitor Tire Pressure, Avoid Excessive Idling, Drive A Vehicle To Warm It Up, And Support Energy Efficient Technologies
um no,   unless you get a twin stick  you could have 2wd lo  and 4wd lo,     but  besides that  no you have to shift into 4 hi then to 4 lo
MiniSimp
Since I've gotten my twin stick I rarely use 4wd at all. 2WD low is soooo nice with a welded rear. :yesnod:
Cheesemaker
I can't wait for my toyota, just so I can have a twin stick!
rrick
Twins stick mean dual transfer cases? I got the v6 so the cost is quite a bit more, as nice as it sounds.
MiniSimp
Quote from: rrick on August 21, 2006, 11:18:25 AM
No, you can have a twin stick with a single transfer case if you want.
