Author Topic: best way to mate a 21 & 23 splines cases?  (Read 1980 times)
fnrunner
  • Member since Apr '06
« on: Aug 15, 2006, 11:06:34 AM »
just picked up an 85 4Runner with EFI , 5spd & 4.10 gears...wheeled it once & was geared waaaay to high - expecially while going down hill! scary! I'd like to keep the stock r&p for now as it's only got 33s so far...
I've searched some & think I have a unique-enough question....I would like to go with a dual tcase setup & have access to a 87 turbo tcase  - would it be best to just use my stock tcase as the crawler box & the 23 spline as the back case or am I bass-ackwards?? I know I'd need the top shifter conv. for the 23 & most people seem to keep the  fwd shift in the crawler box (check!) & top shift in the back (convert the 23-check!)....and can't forget the new cross memeber...
Also thinking about keeping the stock gears for now...I like to try things stock first so I see the advantages to upgrades first hand.  :thumbs:
Thanks for any input / opinions....... :beerchug:
Eric
Re: best way to mate a 21 & 23 splines cases?
« Reply #1 on: Aug 15, 2006, 03:27:41 PM »
sounds like you did your research,  yes  the 21 spline you have would be your crawler, then use the complete  23 spline in the rear
its gonna be sweet  :woohoo:
i know mine is  :eyebrow:
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #2 on: Aug 15, 2006, 09:25:58 PM »
Always put the 23 in the rear, so it gets stronger as it gets longer.
cheap sunglasses
  • Turtle Points: 59
  • Male Posts: 256
  • Member since Dec '05
  • Soon to be shorter and slower :)
« Reply #3 on: Aug 15, 2006, 11:51:48 PM »
:yupyup:
'82 on 35's, not much else.
Chopperman
milla85
  • Male Posts: 180
  • Member since Jun '06
  • 85 in da house!
hi on lux
  • Male Posts: 208
  • Member since Jul '06
« Reply #6 on: Aug 19, 2006, 06:21:02 AM »
how would it be operated on....(dual-tcase set up)..do you mind telling a newbie how it works?
but i do understand how twin-sticked tcase works.
thanks,
ted
fnrunner [OP]
« Reply #7 on: Aug 21, 2006, 08:14:18 AM »
Thanks for the replies! Going to tell my g/f my new quote for the day! haha!! :hahaha:
 :beerchug:
Last post Jan 31, 2006, 08:05:00 PM
by wrenchtech
Last post Aug 16, 2008, 06:47:40 PM
by Duffil
Last post Oct 27, 2009, 06:03:23 PM
by axled89
Last post Oct 20, 2009, 09:33:35 PM
by Blingn
Last post Nov 19, 2010, 04:19:35 AM
by BUDDERS
