Transmission gear ratios
Started by wood, January 10, 2004, 09:57:27 PM
wood
I was wondering what the gear ratios are for each gear(1-5) including reverse in a G52 transmission. I know 1st is 3.93:
New project--1988 4Runner Currently stock, but not for long!
www.HCOR4x4.org
Marlin
I'm at home on my laptop---
1  3.93
2  2.33
3  1.71
4  1.0
5   .85
Rev  4.74
This is from memory, I will correct this tomorrow a.m., if wrong
Marlin
wood
Thanks for the quick responce. I am wanting to get a 4.7 for the rear case and was just wondering what my gear options would be.
www.HCOR4x4.org
