RELLY NEED HELP FIGURING OUT STARTER WIRING A.S.A.P HELP!!!
Started by Doc Holiday, August 07, 2006, 08:00:58 PM
Doc Holiday
Ok here is my problem, i have problems with my wiring for starting my truck, this is what i did today, ok so i have one wire coming from the ignition, another wire coming from the starter, and another wire coming from the battery, when i touch the wire coming from the starter with the wire coming from the battery the engine cranks over and starts, but how do i conncet the other wire coming from the ignition so i can use the key to start it and not start it by touching the other wires.
Can someone please help, i need to solve this problem today, and i am running out of daylight.   PLEEEEEEEEEEEEEEASE HELP ME!! :help: :help:
i also forgot to mention that my truck is a 1980 toyota 4x4 with a 20r and i also have push button, my main concern is figuring out how to conncet the ignition wire to the wires coming from the battery and the starter!!
just run the wire from the push button  to the small terminal on the starter
thats all
Doc Holiday
Doc Holiday
YeeeeeHaaaaa, it works, should i be worried about my battery exploding i dont have a fuse to it.  basicly this is my setup, i have the wire coming from the push button dirrectly to the wire coming from the starter, it seems to start right up.
Thanks Coyotee.
:wave:
