Toyota Drivetrain in a Suzuki?
Started by Destruct O, July 26, 2006, 12:38:51 PM
Destruct O
Is it possible to put in Toyota's 3RZ Engine and a W series Transmission and a 95 gear driven T-case?
Into any Suzuki?
Destruct O
DN1911
curious why you would want to? the samurai is a much inferior platform to start with and requires extensive modification to be a good trail machine. i have watched a good friend try to build one the few years. it is a good rig but still has some major shortcomings. nothing is left of the stock suspension, 4linked front/rear, stretched wheelbase, list goes on and on.
Destruct O
I was just curious if it could be done and to see if any one else did it. The 3Rz is a nice 4 cylinder I always wanted a Japanese convertable that had a solid axel and it seems samurias are easier to come by than the FJ40s
Destruct O
DN1911
i have seen Toyota Sammies in magazines so i'm sure it can be done. if you want a Toy convetible look for an early 4Runner. they are perfect on the trails
It can be done if you want to hook your rear axle up directly to the transmisson and skip the driveshaft. :rofl2:
i would run a 4AGE  into the zuki tranny
or a Mazda rotory
Destruct O
Quote from: 79Coyotefrg on July 27, 2006, 11:06:52 AM
or a Mazda rotory
HMMMM! A rotary engine like what is in the RX-7
Destruct O
Yup, I have heard of this conversion. I have never seen one but it has been bounced around by a few people I know of that have Sammi's.
Quote from: Destruct O on July 30, 2006, 09:16:25 PM
YES  the RX-7 rotary engine,  they are extremely lightweight,  about equal to the 1.3L and can be modded to 500HP
and i think the bell housings  are very close,  not to mention having a 12,000 rpm redline :yikes:
pickemup81
In disney oklahoma russ hogan runs portals with a rotary motor and a sammi tranny. Its bad arse.
86 4runner now with sas and other garbage
Rob_O
I've got a sammi with all the Toyota stuff (22RE/tranny/solid axles). Bought it as a runner, its a hack job so I have lots to do and/or redo but its a hoot to drive. Right now it is just stock truck parts rolling on 31's, future plans include Jeep springs, 34" LTB's, 5.29's, 4.7 transfer case and crossover steering.
Buddy of mine has one stretched and linked on 35's with 22R/toyota crawl box/Dana 300/Dana 44's. When he finds a turbo tranny, its getting the 3.4 Taco V6 he has sitting in the garage
With the 22R(E) and stock wheelbase you can use a stock front shaft as the rear shaft. Cut the radiator support to move the rad forward and keep the engine fan or get an electric one on the front of the radiator. That's how mine was done, everything but the electric fan and the extra front shaft came off a rusted POS donor
3RZ might be a little harder as I understand the bellhousing is longer. I'm not going to try one until I have a bellhousing that works with the turbo tranny in my parts collection
Hope this helps!
wezzlegod
im putting a 22re, L52 trans and duel t cases into a sidekick. movig the rear axel back ad replacing it with a toyota ass well as a tyota front.
wildchild1066
mines all yota . pics down below this thread in show pics or somethin like that . last page . i'm runnin 38s
UNLEASHED IN THE EAST
Mikeyg79
of course it can be done. Anything can be done. I'm sure someone could put a 4BT/NV4500/Stak/toys w/mog outters in a Sami - just a matter of how much work you want to do.
MR_DIY
samurai's are a GREAT platform to start with.  and the swap can and has been done lots.
I'm a samurai guy as well as a yota guy and would honestly prefer the samurai tub on my frame rather than the cab but I've done too much work to my cab to ditch it now.
zuwharrie.com will help you out A LOT.  :twocents:
I'm going yota JUST so I can buy from Marlin more.
*quote*-  goes to show that a ramp hero doesn't always have what it takes to be a trail hero as well.
The problem I would foresee with putting a toy drivetrain in a sami is just how long it is.  This may not be an issue for you if you have a lwb sami though.
arrowbee
i have a dana 44 in front and a 14 rear,extended front and rear 6 inchs ,but im in the proccess of building the front drive line any ideas,i though about to on top and then cevy on bottom!
YARDSALE!!!
gigalo
my buddy is thinking of doing the 22r and yoyo axle swap here soon
1985 4runner sr5! being built
gigalo
