What is anchoring this setup?
Started by scott.475, January 06, 2004, 03:39:37 PM
scott.475
Isn't this a chain driven t-case on the rear? I don't know a whole lot about t-cases, but from the looks of the shifter base it looks like a chain drive. What gives, and if it is, why?
This is the triple posted on the Marlin site, btw.
gferris5
that looks to me like two gear driven cases, an adapter, and a chain case on the rear. I'm no t-case expert either, it just seems like the give away since the output is on the driver's side-probably from a tacoma, it might be someone who wants a triple but has Taco IFS still or has a driver's sided diff axle. That's just my guess-and it looks like it kind of answers your question.
89 toy
is the clutch fork and slave cyl on the wrong side ? all the ones I've delt with are on the other side
CruzrDave
Thats a Tacoma Trans and T-case. We just bolted a triple up for the fun of it( look close, its missing bolts ). You can stack as many case as you have room for, but it's just for braging rights. A dual case with 470 gears is all you would ever need. I don't know of any one useing our MC09 Taco Crawler in this triple setup.  Most of our Tacoma customers retain there stock left hand drive T-case when doing a dual case swap.
Taking back America, one part at a time! :madeinusa:
scott.475
i'm guessing the Taco cases are chain drive too. How are they working out for the guys that keep them?
