drill them out and run half inch bolts thru them
do one side at a time, pull them out drill out hte hole in the middle to 1/2" and run 1/2" bolts thru them and bolt them back in. grrrrrrrrraaaavyabout half way down- "Motor Mount Tech"http://www.pirate4x4.com/forum/showthread.php?t=459180
yea- I read that link... thanks... I just didn't know whether to drill from the bottom center of what? guess that's it. thanks
take one out and it will all make sense, theres already a small hole in the center, just need to open it up to 1/2", then run your bolts up from the bottom so the nuts are on top
This is what I did about 3 years ago. I run a nylocks nut with a lock washer so that I can leave some play in it to help with vibration. I have never had an issue with them comming loose. I also put a little piece of mud flap between the bolt head and the nut. Oh yea I use a grade 8 also. Kevin
on the pirate board it mentions that this setup with poly bushings causes more vibrations on at higher speeds? are these motor mounts going to be an issue on the highway
it is noticably more rigid, mines 95% trail only so I'm not concerned
Started by vikingsven Project Research and Build-Ups
Started by croberts Toyota Pickup/4Runner Tech 1979-95
Started by Bloomcounty Toyota Pickup/4Runner Tech 1979-95
Started by Dr.Maxwe001 Engine
Started by Rockin4Runner Engine
