Author Topic: 22re question.  (Read 1976 times)
Tice
  • Turtle Points: 8
  • Male Posts: 881
  • I named my son Wheeler!!!!
22re question.
« on: Jun 06, 2006, 08:44:48 PM »
Is there an easy way to tell what year a block was made, or about what year?    Also, the bore of a 22r is 3.62 inches, the motor I picked up is 3.623. Is that exceptable? There is no ridge on the cylinder walls, though I can no longer see any hone marks. All I want is a motor than runs well and has O.k. power and doesn't smoke.  I can barely do 55 ona flat road and forget about hills or any incline for that matter. Thanks for the help. :beerchug:
www.wheelingarizona.com
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
    • PhotoBucket
Re: 22re question.
« Reply #1 on: Jun 06, 2006, 08:57:28 PM »
Is there an easy way to tell what year a block was made, or about what year?  :beerchug:
I called my local Toy dealer and gave 'em the block number.  All they could tell me was it was pre-85, and that before 85 they didn't keep very good records of the block numbers.
Or you could PM reklund and see if he could run it for you.
« Last Edit: Jun 07, 2006, 04:33:57 PM by Duffil »
BoG-ToY
  • Turtle Points: 594
  • Male Posts: 2,122
  • Member since Dec '05
Re: 22re question.
« Reply #2 on: Jun 07, 2006, 12:15:55 AM »
AERA allows up to .007 of wear on a re-ring with CAST IRON rings the sounds good to me.....if your running it as is...run it....if not....re-ring it make sure you run cast rings tho? just my opinion
Prismo
  • Turtle Points: 8403
  • Member since Oct '03
  • Living in the green house
Re: 22re question.
« Reply #3 on: Jun 07, 2006, 12:29:02 AM »
Heck, I would probably have it honed & re-ring it. I would probably do the crank bearings/bushings & rod bearings at the same time. I have seen many a rod knock in Toyota 4 cylinders.
toyman1994
  • Turtle Points: -32
  • Male Posts: 59
  • Member since Jul '05
  • I reject your reality and substitute my own...
    • Wheeling Arizona
Re: 22re question.
« Reply #4 on: Jun 07, 2006, 05:12:28 AM »
See, that is what I told him too, but nooo, he has to ask everyone else.  I've got the hone, so when you want to do it Tice?
RynsToy
SAS'd and Caged 94 PU on it's 4th set of tires in 6 months and hasn't moved an inch, currently, stock '65 GMC wheels.
RIP: Corporal Victor M. Langarica - 20 Jan 2007
Tice [OP]
  • Turtle Points: 8
  • Male Posts: 881
Re: 22re question.
« Reply #5 on: Jun 07, 2006, 02:49:31 PM »
 :spankbutt:   Thats what I was planning on doing!!! Call me tonight and I'll come get it. The bearrings are needing replaced.   But now I need to figure out what year it came out of. Engnbldr has to know for some reason.
Last post May 11, 2005, 10:37:20 PM
by Uncle Jesse
Last post Dec 12, 2005, 06:12:17 AM
by Zoomschwortz
Last post Mar 28, 2006, 04:16:19 PM
by bmxanddie
Last post Dec 16, 2009, 07:18:50 PM
by skinneykansas
Last post Jul 14, 2006, 01:16:21 PM
by UGLYTOY
