Comparo Question: Welders
Started by CTENG in KS, June 06, 2006, 05:47:23 PM
CTENG in KS
Speaking in terms of 110V machines here:
Will a small 90-100 amp arc (stick) welder get better penetration on 1/8 - 1/4 than a comperable MIG or wire feed unit?
BoG-ToY
well you can use a higher penatrating rod....but I beleive that flux core can burn pretty deep......but I wouldnt go less then 120 amps on either.....my hundred amp wire didnt like being abused and on stick Im always running 118 amps on 1/8th 7018 (70k lbs tensile strength) and watch out for that killer the duty cycle...I have a 150 amp 100% duty cycle welder.....at 300 amps its 20% duty cycle......most cheap machines have a 10-20% duty cycle at 100 amps....so keep that in mind......duty cycle= minutes of use over ten minutes.....20%=2 minutes welding 8 minutes cooling.......
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
