Chewed up transfer case
Started by bs3, June 05, 2006, 07:45:19 AM
bs3
Greetings, i have a 1974 FJ40 with a transfer case problem.  It was making a ugly noise so i checked the fluids, found the transfer case oil to be the shiniest so I took it apart last night and found the damage shown in the pictures above.  It has a four speed transmission, SBC 350 engine and a transfer case from a unknown year, the guy i bought it from thinks its from a 1975-1978 and from what i can tell i think he is correct.  I'm having trouble finding why the transfer input gear was "hole sawing" the case just forward of the gear,  the transmission has the input gear stopper is in place, the only thing i can't tell is when i pulled the transfer case back from the transmission what position the input gear was in (whether it was put in backwards with the seal surface facing aft allowing the gear to contact the case) but that doesn't seem likely.  The only other damage i found was the cluster gear shaft and bearings were trashed.   The other possibility is that at one point somebody assembled the transfer case wrong, the above damage occurred, they pulled the transfer case back off and corrected the problem but didn't replace the housing, this might be the most likely scenario to me as the input gear had no contact marks at all.
Anyways i was wondering if anybody had seen anything like this before, any help would be appreciated.
LCOwner
Chuck that case in the recycle bin and buy an Orion
'71 FJ40, 350 TPI/420, 4.70/mini, 60's/5.38/42's, under construction.
'83 FJ60, SOA underway.  Soon to have a Police 350TBI/700R4/.....
Hill Hoppers Central Valley 4 Wheelers - Founding Member
Four Wheel Drive Club of Fresno - #1127
bs3
I hear that, after thinking about it today i put a order in for one at AA.
lc tpi
 im pretty shure that the four speed should have a spacer on the output shaft sandwitched between the bearing and the input gear. if this is missing this could be your problem.
66 fj40 , soa, sr, tpi 350 , 420 rockbox 37" mtr's ft arb 30 spl longs rr fj60 ff poly shafts detroit.       67-fj45lv , 67-fj40 , 72-fj40, 74-fj40 , 83-fj60.
