Injectors
Started by pickemup81, May 23, 2006, 01:12:01 AM
pickemup81
I am converting my carb engine to fuel injection. I was just wondering what kind of injectors are the best for a stock engine.
86 4runner now with sas and other garbage
brainlessfool
:werd:
I think the later model orange and blue injectors are 200cc, and the early style gray injectors are 180-ish cc
boggerunner
what are the red injectors?
pickemup81
The reason I posted this is because this is the first time i have messed with fuel injection and I have had alot of problems with the local parts stores trying to give me the wrong parts.
you arent going to get OEM injectors at a local parts store most likely.... they will sell you whatever brand they have
94SRUNNER
Check eBay for the stock injectors
Insured by Smith and Wesson
boggerunner
i have a stock set of injectors for sale, but i will have to see what color they are
Weldo
This is how LC Engineering lists 'em.
22RE Type-C (83-88) 195cc 2.5 OHM
22RE Type-E (88)
22RE Type-F (89-95) 195cc 12.5 OHM
As far as the color goes, I got the Type-F ones for my truck, they are red.
LC sells them in sets of four for about $200 with a $50 core.  They are rebuilt and equalized.
abnormaltoy
#9
You have to match the injectors to the harness. For example the 88s are year specific...one year only. So, if your scabbing parts make sure to get everything you can from the donor truck.
Mark
-- Winston Churchill
Travis Tritt (I know!)
pickemup81
Thanks for your help fellas. I decided to just go with some of the lc injectors. I was just going to get some from a local parts store but they were charging 240 bones.
pickemup81
Well im broke so im now unable to go with the lc injectors. :down: Is there a way to test my old injectors. They look pretty decent. All it looks like they need is the rubber bushing that goes over the cap. Does anyone know where i can get the rubber pieces? :help:
lilbuddy
Well you can send them in to get tested. Team Ramrod did that. Heres a link to his buildup:
http://board.marlincrawler.com/index.php?topic=13244.msg219039#msg219039
If it doesnt go to it, its reply #65
RIP Kyota.... you are the man
GET IT!!!
abnormaltoy
Another place is to service your injectors is http://www.rceng.com/
What year did the EFI system you have come out of? I have (somewhere) a set of LC injectors for an 88. I will not be using them.
pickemup81
what im doing is putting my 22r in a fuel injected 86 runner. All I really want to  do right now is get it running. the injectors look alright for now i just need the o rings and the rubber bushing that is over the cap. I will get some new ones as soon as I get some cash.
Sundowner
Quote from: pickemup81 on June 29, 2006, 12:13:58 AM
when you have the cash, send your injectors to cruzin performance (google it) for $50 they clean and test your injectors and ship them back. they also give yout the spec sheet for the test on-line as soon as it's done, which is pretty cool, too.
MAKE SURE YOU GET NEW O RINGS AND INSULATORS!
make sure they're TOYOTA. accpet no substiutes. I tried three different o-rings on my injectors before sucking it up and paying $4/oring at the Stealer. but they work. cheap crappy harbor freight o-rings just spew gasoline down the intake and onto the ground.
havik
any body ever notice a differance in running balanced injectors?
got another 85 runner. build coming soon!!
boggerunner
yep i had a problem with some non toyota injector orings, well had some brand new orings in my rig from the local auto parts store, then i had a small engine fire, and now im runnin v6 injectors, cause my 22re ones are all melted from the fire, thanks checker auto parts
