Sounds like an axle bearing to me.Take the rear shaft out and drive it on the front. If the noise is still there it is in the rear end.You could also spin the rear up and put a long screwdriver on the axle housing and listen to the handle. If you here a grumbling in the handle it is the bearings.
Started by vikingsven General 4WD Discussion
Started by ron4pres Engine
Started by dok33 Engine
Started by Rebeltilldeath3 CB and HAM Radio Tech
Started by GoaT Engine
