Author Topic: Where can I get E-locker motor parts  (Read 1191 times)
Bloomcounty
  • Male Posts: 115
  • Member since Mar '05
« on: May 17, 2006, 06:07:19 AM »
Just like the title says , other than a dealer ? I may need some brushes , armature , or the little limit switch inside ! The guy I got it from wired it wrong and I'm worried it's needing parts ! Or replacing .
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Where can I get E-locker motor parts
« Reply #1 on: May 17, 2006, 09:31:41 AM »
try and see if it works by jumping the terminals
jack one rear tire up  then get under the truck,   therea 5 pins  in  the locker plug,
I   I
I   I   I
1  2
3   4   5
put 12volts to 5  then cross  1 and 3  and put a ground to 2
if you hear nothing  then
cross 2 and 4 and put ground to 1  with 12volts  to 5
if you still here nothing  you need a new motor
Last post Sep 29, 2004, 06:20:32 PM
by FIREBALL
Last post Oct 17, 2006, 04:59:50 AM
by Bloomcounty
Last post Oct 30, 2006, 12:13:11 PM
by Bloomcounty
Last post Nov 18, 2006, 03:40:36 PM
by 79coyotefrg
Last post Apr 25, 2010, 12:47:04 AM
by havik
