3 link rear
Started by rockwalker, May 16, 2006, 07:57:42 PM
rockwalker
i'm going to build a 3 link in the rear of my 4runner.  I have lower made, just need to finalize the upper link.  I want to run it straight above driveline like a traction bar and then run a panhard bar.  Lowers will be same location as leaf springs.  My lower are 4130 .375" :inthedark: wall with Johny's, and they are 44" long.  i will be using air shocks.  The upper link would mount in the center with two mounts above each other like a 2link traction bar.  does anyone have pic of use straight style, i have seen one 4runner that was a the cover of 4wheeldrive it was orange it had something like this, need pictures.  Billy
85 runner with 3RZ  linked  locked  and ready  2rock
http://board.marlincrawler.com/index.php?topic=40729.0
87 tintop..........................................................
Paulie
Sounds like your ass end will walk beside you.
Why not just run the standard 4 link. triangled uppers and parallel lowers. run bushings at the diff and your JJ at the crossmember. you will not need a panhard if you run that setup
85 SR5, ARBs, Hi-steer, 35" Krawlers...has most of the right parts
alwaysbroken
are you going to be moving your fuel tank behind your axle?
89 4 Runner, 3.0, 5spd, 2.28 crawl box, 4-1 atlas, prorock 60 up front, crd60 out back, on 37" mtr's
Ramrod
Dude Billy whats up this is pat.  I've seen a few 3 links and they all had the lowers set up like the leaf springs then they had the one upper and the panhard both sharing a mount on the passenger side.  With that setup you can still use the stock gas tank and supposidly they drive good.  One of the trucks was in santarosa from a guy I bought some stuff off and he had those johnny joints  and the other was  fourrunner I saw in santa rosa but I didn't get a close look
rockwalker
i've seen a lot/Users/billysmith/Pictures/iPhoto Library/2005/11/20/attachment-2.php.jpg
i want to use stock gas tank location.
Ramrod
theres a dude on pirate from sr named ROCKILLER with that on a 4runner
locktup
Why not use triangulated lowers ^ and something like this for uppers        :flamer:
               0                     0
                 0                   0     FUEL TANK
                   0                 0
                     0               0
                       0oooooooo0
                         0           0
                           0         0
                             0       0
                               0     0
                                 0   0
                                   0 0
Quote from: MUDDONKEY on November 29, 2005, 05:23:59 PM
LOCKTUP SHOULD HAVE HIS OWN DISCOVERY CHANNEL SHOW!!
www.LOCKTUPFABRICATION.com
rockwalker
i have seen that on praite thinking about some like that.  How much on lower?  would that work as on road as off road.  I
Skinny_Pedal
Quote from: Paulie on May 16, 2006, 10:40:23 PM
hense the panhard
Im an OG
Stinky
Quote from: Skinny_Pedal on May 19, 2006, 04:44:08 PM
hense the panhard
ya,i saw that setup on the white runner on pirate...but no panhard bar, the top link/triangle keeps it laterally stabile, hence NO track bar....but i dunno about that on the street...but im doin it anyway...
87 p/u SAS, 22RE, built, then cut up and scrapped
94 ex cab P/U, SR5, fully loaded, 3.4 swap, r150f, a/c, bumpers, 33s, glass fenders...sold
00 Stoopid Duty 250, ex cab, lariat, v-10,000
94 reg cab, 22re, duals, 38.5 boggers, sas, 4 link, tube bed, build underway... http://pirate4x4.com/forum/showthread.php?t=967836
88 Samurai, soa, buick 3.8, th350, zuki case, 1/4 done... anyone wanna buy it??
rocktoy83
Quote from: locktup on May 18, 2006, 11:30:54 PM
               0                     0
                 0                   0     FUEL TANK
                   0                 0
                     0               0
                       0oooooooo0
                         0           0
                           0         0
                             0       0
                               0     0
                                 0   0
                                   0 0
I am going to 3 link the rear of my toy like that in a few mounts and i would like to know how long to make my lower and upper links :help: Thanks
boggerunner
here is a pic of my upper link on my 3 link
Stinky
Quote from: rocktoy83 on December 30, 2006, 09:00:10 PM
the top triangle you can mount on the main frame crossmember...
measure n see how long it'd be and just make the bottoms the same length
rocktoy83
Quote from: Stinky on January 01, 2007, 05:01:33 PM
I was thinking about mounting the triangle link to the fame crossmember :thumbs: , but did not know if the bottom links shooed be longer :dunno:
boggerunner
u want the bottom bars longer so that the pinyon always rotates to the t-case
Stinky
yes...thats right...but not too long...id say 8" longer...if its too long it'll pitch down alot...make mock-up links n cycle the suspension to check...and adjust accordingly
