jeep yj springs for SAS???
Started by Marc P, May 13, 2006, 08:46:32 PM
Marc P
I just got a set of heavy duty YJ springs. They are stock height. and I wonder if I can use them for my upcoming SAS on my 95 4runner. Has anyone done this??
If it will not work, I will find some Toy rears and use some of the YJ leafs.
Need some input on this one.
1998 4Runner--under construction
RockSlayer
My buddies up in Washington liked to use the YJ 4 inch lift springs when they did a SAS. They flex great! One guy even used the YJ spings on his 3.0 Toyota V6 powered Sami. I think you can even squeeze the YJ springs into the stock Toyota spring Hanger and Shackle, but I don't know from first had experience.
Paulie
personally stick with either stock rears with a mix of leafs or waggy leafs. i had a set of YJs in my last rig and they failed big time, ever seen a leaf spring make a perfect W
85 SR5, ARBs, Hi-steer, 35" Krawlers...has most of the right parts
Marc P
My plan now is to use stock rears up front with a mix of the Yj leaves to get it to the right height/ride I want.
