Has Anyone ever ran 35 inch tires with stock gearing in a toyota first gen
Started by Doc Holiday, May 11, 2006, 04:00:53 AM
Doc Holiday
hi, i have a 1980 toyota 4x4 shortbox 4 speed 20r, with a 4 inch lift, i was thinking of putting some 35 inch BFG mud terrains on for awhile intell i can aford some gears, has anyone ever ran a 35 inch tire with stock gears before , if so how did it drive, was it gutless, also will this burn out my clutch, the tires will only be on for one camping trip.
HELP!!!, thanks
blackdiamond
Quote from: Doc Holiday on May 11, 2006, 04:00:53 AM
HELP!!!, thanks
I noticed a huge difference in my 85 (22R) when I swapped out my 32 inch tires to 33 inch tires with stock 4.10 gears.  I'm sure it would have handled it, but I quickly had the gears upgraded to 4.88.
I would save the tire money and do it all at once.  :twocents:
mudmaster
I ran 36's with 4.10's, 5th gear was out of the question and I had to slip the clutch alot going up hill off road. In my opinion I'd get the gears and tires at the same time, I got 5.29's.
Time to go wheelin!
skid
Run it, I've been running the stock diff gears for a long time on 37's.  No jack rabbit starts, but it wasn't built for that.
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
HELP!!!, thanks
look at your axle codes on the right front fender, if it says G292  then you have 4.10 gears
if it says G102  then you have 4.37 gears
you could get by with 33's for awhile maybe but 35's  :aaa:  you will roast the clutch the first trip
skid
I've been runnin a 22r, l43 on 37's for a year, but I did do a clutch before.   Wasn't till February this year that I put in dual cases.  I say run it and save for a good Marlin clutch and gears.  Also had a 84 with 36's on 4.10's, no problems.   Depends how serious  the wheeling is.
Quote from: skid on May 11, 2006, 10:15:44 AM
:yikes:
Holy broken tranny batman :yikes:  you have officially exceeded the life expectancy of the L43 tranny :aaa:
its actually a 2wd tranny  and very week,  dont be surprised if it blows apart anyday
i put my L43 back in awhile back but just to get by till ican afford to have my 5 speed rebuilt
skid
Quote from: 79Coyotefrg on May 11, 2006, 10:25:18 AM
:yikes:
ummm, Actually my second tranny.  First one suffered from a dissappearing shift fork(broke, ground up and drained out the the drain plug).  I forced the one two shift too many times with the marlin clutch.  On a good note, I have a w56c on the flloor in my garage.  Which should be a upgrade for everyone with a L43.
BUBBA
I ran a 79 with stock 4:37 gears,35's, and a L43.I did eventually swap it for a w56 but it still worked,it needed an input bearing.D/D and wheeled it for 2 yrs like that.Even with a welded rear.
My budget beater
kyle_22r
my 20R, L43, 4.375 combo SUCKED even with 235/75R15 tires!  then again, it had 300k on the clock and about 60 horsepower, so that could've been why.  the poor thing could barely hold 50 on a grade.  it wasn't bad at all with the new built engine and 5 speed, i could do 70 no problem.
one of hte biggest factors that'll kill ya with the L43 is it's lame 3.67:1 first gear.  as if you didn't have an anemic worn out engine as it is, you've also go that high gearing to contend with.
and you can really notice the difference with the 3.93  and 3.67 1st gears,
i had the L50 for awhile  and loved it, but it started jumping out of gear  so i changed back to the 43  and dang that 3.67 1st sucks
CTENG in KS
Yes, the clutch chatter was unbearable...switching to 5.29's fixed the issue.
i run 31s in my truck with stock 3.07 gears, and a w55 -- the stock sized tires on my truck were 195/75/14
regular driving isnt so bad, but san francisco toasted my centerforce
oh yeah, i snapped the output shaft on the tranny as well
yotaweelr
my 80 toyota hauled with 35" tires and 6" of lift. with a 20r, that stupid side shifter trans, and 4.30 gears. I liked it better than my 81, with 22r, w56, dual cases and 4.88's with 35"s now 37's. and tell you what, I never had problems with my l-43. only with my w-56. trail running all you need is a dual case, don't regear the axles.
Doc Holiday
i wonder what type of crawl ratio you would have if you ran 571 gears with 31 inch tires and dual transfer cases ( both cases having crawler gears )  imagine that!!!!!!
DTB
Quote from: Doc Holiday on July 16, 2006, 09:45:33 PM
according to my calculations (which are probably way off) around 12613.39:1
i seriously hope you are joking... what happened to you posting in the docs question thread?
sandboxtoy
I RAN 5:71 WITH 31'S AND WAS ABLE TO BEAT NEW CHEVIES IN A STREET LIGHT DRAG, SHIFTING INTO 5TH AROUND 40 MPH, BUT NO GOOD ON THE FREEWAY, THOUGHT THE SQUIRREL WAS GONNA DIE
DTB
Quote from: sandboxtoy on July 16, 2006, 11:32:46 PM
WHY ARE YOU YELLING AT US?  :cheese: :hahaha:
