Front drive line assistance please....
Started by RCKSQRL, May 10, 2006, 12:33:30 PM
RCKSQRL
trying to figure out how much slip you all are running. I have marlins 4" (so I am told) lift springs with 1" lift boomerang shackles. I know that the stock will not work with any flex and I haven't taken it out yet to try. I will be needing to lengthen the fron when I throw in the duals I have but am unsure how much slip I should need safely.
Thanks in advance!
'85 EFI Runner
4.3 with 700R4- for sale
5.29 detroit F/R
Front 3 Link with air shocks
rear 4 Link
Custom Fuel cell
8274
Crawler #719, rear with 4.70 # 677,
Twin stick
Skys manufacturing T-case crossmember
6 point cage modified with harness bar, dash bar and PRP seats mounted to cage
2 feet chopped off the back
It seems it is never done........
in works for new body and exo, motor and trans swap...
do a little driveway flexin,  if you can see splines  then you are about to pop it out,  only a bout 2 inches shows befor its flopping in the wind
RCKSQRL
all fine and dandy, how much slip does yours have?
wondering if the 8" @ marlins would be enough and if so how much is "normally" set for droop ect. That is what I am going for.
thanks
'85 EFI Runner
5.29 detroit F/R
rear 4 Link
Custom Fuel cell
8274
Twin stick
RustyToy
if i'm not wrong its about driveline angle also...
MiniSimp
I'm running 31" of slip. Just barely enough. :greengrin:
Ramrod
I have 3" of uptravel and 12 of down and have been worried I was gonna pull it apart before.  You really only need about 2" of uptravel though if that.  Just flex it out and messure the distances
krawlz
31" Holy Crap! Thats, umm.. umm.. thats more then two feet.   My drivelines barley longer then that.
My local driveline shop, which happens to be High Angle Driveline. built me a driveline with 14" slip. I've got the
4" marlin lift with dual Case's. A good driveline shop will have slip stock that they cut to whetever length you need. I would not
recommend the marlin yoke. sorry marlin
Any man, in the right situation, is capable of murder. But not any man is capable of being a good camper.....So, murder and camping are not as similar as you might think.
Some men are alive simply because it is against the law to kill them.
MiniSimp
Quote from: krawlz on May 10, 2006, 09:41:59 PM
Ok, it's more like 25"
Gotta love square driveshafts. :greengrin:
krawlz
OK square driveshaft. I get it.
bottom line Maggot, 8" is most likely not enough. Id ask some of your
local guys, who's a good shop around your area and take your rig to them.
I think they would know best for your rig.
MiniSimp
crapyota
mine has 3" of compression and 16" of down travel havnt realy flexed it far enough to see the yellow paint i put on the inner shaft's last 3"(square driveline)
88-4runner 35 boggers,5.29s,locked in rear. finally got a sas!!!! pics at photobucket(crapyota)
checkout www.nw-wheelers.com
RCKSQRL
Quote from: MiniSimp on May 10, 2006, 10:09:53 PM
yeah, 12" or 14" minimum.
cool, this is what I was looking for. Thanks all for the input!
'85 EFI Runner
5.29 detroit F/R
rear 4 Link
Custom Fuel cell
8274
Twin stick
86turboyota
im running marlins 8in slipjoint and its plenty of slip for my setup... not sure what you guys are running that requires soooo much slip...
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
Ramrod
Quote from: 86turboyota on May 11, 2006, 10:42:07 AM
If you ever do the rubicon and try the soupcan your shaft will pull apart thats the only place i've ever needed it I can think of
krawlz
Quote from: TEAM RAMROD on May 11, 2006, 01:45:24 PM
I don't recall anybody saying this is the "soupcan" when i was on the rub. witch part of the rubicon is that?  :headscratch:
crapyota
the marlin slip yoke will work you just have to extend main tube also..
i extended my main tube 4 or 5" but didnt have a longer slip yoke and the yoke would come apart driving over a speed bump. you need both. i went square becuase it cost me $20.  marlin slip yoke and extending main tube will work but looking at $200 plus.   for now i can afford the cheap square and for some reason the trail i run require me to have alot of flex and realy needed suspension droop i know my front drivline useses most of its slip so yeah  16" is about what i need.  sorry marlin when i got the money i will look into it but right now i need to save $$$$ for a marlin hy-steer(spend $ wisely so i can keep wheelin) :twocents:
