triple cases ?
Started by 89 toy, December 12, 2003, 10:00:47 PM
89 toy
now that i figured out what trans and tcases i have. is it possible to run 3 cases? im going to run a w56trans with a tcase off a g54 with a top shift adapter and the rear case will be off the w56. i have another tcase off a g54 is it possible to put that in the middle with a top shift kit?would i need just another adapter plate? it's just laying around why not use it just for shits and grins?
CruzrDave
Yes you can run a triple. You would need to make the rear case be a 23 spline. Two case in the front( 2.28:1 x 2.28:1 = 5.19:1 ) is to much torque for a 21 spline input gear.
Taking back America, one part at a time! :madeinusa:
89 toy
can i buy a 23 spline gear or do i need to find a 23 spline tcase from a turbo truck?
CruzrDave
You can still buy the gear from Toyota or us. The 23 spline coupler will come in the adapter kit just make that known when you order.
89 toy
or if i get a assembled 23 spline tcase with 4.7 gears from marlin what would i need to make that fit the tcase from the g54 tcase?
