Mile Marker Electric Winch?
Started by crx-si, May 02, 2006, 07:02:23 PM
crx-si
wa4x4
Good to see you put so much thought into your post.
Milemarker has been around awhile,  i would prefer Warn  but if its cheaper :dunno:
crx-si
Ya i thought about warn but i have heard warn is made alot cheaper that the older ones, as for the milemarker the price is right and have been hearing good things about them.
Warn  is top of the line,  how much is the MM??   800 for a 8000 lb is about normal
Shamb
mile marker is good winch, it relies on gear reduction instead of Horse power. So it is SLOWER than a Warn or Ramsey but it pulls like a mule. I had to custom "water proof" mine so the electircal box didn't get wet and start wiggin out on me. Other then that its a great winch for the price and it'll save your @$$.
Ramrod
look into the winches summit racing is now selling.  You can get a 9000 for $450 to your door and it specs out better than the warn
crapyota
my buddy has a hydrolic 9000lb milemarker it works good every time we need it. slow as hell.
i bought my warn 8274 old and used for $400 will out pull his mm. and by the time he gets his cable in i could be down the trail and relaxing
88-4runner 35 boggers,5.29s,locked in rear. finally got a sas!!!! pics at photobucket(crapyota)
checkout www.nw-wheelers.com
crx-si
Quote from: 79Coyotefrg on May 02, 2006, 07:44:56 PM
About $450 new for the 8000, good deal.
mudmaster
I've got the MM 12,000. It is slow but in my opinion the drum is too small and the cable will easily wind to one side when under a load and break the housing. That said it was covered under warranty. A friend also did the same thing with his 9,000 MM. My old (1970's) Ramsey never had this problem. It was a 8,000 with 150' of cable.
Time to go wheelin!
red
personally i would go with a hydraulic, far less likely to overheat, and comes waterproof from the factory (very nice if u do water crossings or mudding), works underwater as well. hydraulics will pull at a faster rate under max load than an electric will, and much quieter. just my :twocents:
both warn and milemarker are great, personally i'd go for the mm. even if you do have a problem it comes with a warrenty, so y pay the extra money? just have to watch that the cable doesnt build up too much in one spot. not that hard
read and comment :whip:
USAF EOD tech
MiniSimp
Quote from: red on May 03, 2006, 08:17:34 PM
Down side = does not work without the engine runnning.
crx-si
Thats why i diden't want a hydraulic winch.
86 4runner
im going to get  a T-max 9,500
86 4 Runner SAS, 37 inch Toyo M/T's, E-Locker rear, Lock Right front. 30 spline Longs, 5.29's, Dual Cases, Warn XD9000i
red
Quote from: MiniSimp on May 04, 2006, 07:33:14 AM
ur right, forgot to mention that. but if you run an electric winch for an extended period with the engine off, ur battery will be dead. (depending on ur battery could only take 1 or 2 minutes with cheapo batts)
USAF EOD tech
crx-si
Quote from: red on May 04, 2006, 08:25:43 PM
Thats why i am useing two batteries.
