what t-case?
Started by red, April 30, 2006, 08:26:36 PM
red
i'm plannin on doing a doubler setup on my suburban and was curious what the best t-case combo would be.
truck would have either a mildly built 350 or 6.5 turbo diesel, and hopefully a manual tranny.
looking for a t-case that would live up to the power easily, has a solid reputation, and can be regeared for cheap.
read and comment :whip:
USAF EOD tech
Duffil
suburban?...prolly 203/205. That's about the most common to double in fullsize stuff, from what ive seen.
yea 205  or maybe the atlas
red
an atlas would be great, but i'm lookin to do a doubler for pretty cheap, buy the two t-cases at a junkyard and rebuild/regear them myself.
i know the 205 and 208 are good, but which is the full time 4x4? this truck will also be a dd.
what other t-cases would be strong enough? a toyota landcruiser case? a dana 300? any ideas would be appreciated. i'm not looking to make monster power from the motor, i'd say 300hp and 500lb-ft of torque would be top (at most)
USAF EOD tech
the 208  is a chain drive case,  the 205  is gear drive, both are part time tcases
the np203  was the full time case
get a 203  and a 205  and use the reduction box from the 203  between the 205 and your tcase
red
so make myself a triple t-case setup? not a bad idea.
USAF EOD tech
