Camber kit????
Started by yotamckimboy4x4, April 23, 2006, 04:18:16 PM
yotamckimboy4x4
Hey guys on my 86 toyota im runninn a 6 inch lift and 34x10.50 super swampers and my tires are bowed and i was told i need a camber kit and it would fix that. where can i get one and what do yall know about them?
"We ride together, We die together, YOTABOYS FOR LIFE"    85 toy pickup 5 inch springs 2inch body lift, 36" IROKS, custom front bumper
"HOLD ON TIGHT"
its basically bolts welded to a washer, they go in the bottom holes of the lift kit
its quite easy to find htem but you have to know what you are looking for, as parts guys at most auto parts stores have no idea what stuff like that is.....
and whatever you do, dont take it to a shop that does alignments and ask them to source the parts and install them for you, they will charge an arm and a leg for basically a $10 part and half an hour of labor......
IronClad
camber adjustments are stock.  see the bottom bolt  how its in this fat washer and to one side?  that bolt has a flat spot and so does the washer.. losen the nut and turn the bolt that will adjust your camber.
Annihilation  Fabrication
Do you need a Hammer?
yotamckimboy4x4
That doesnt matter. cus when i had it alligned they did all that and said i still need a camber kit and when you look at the tires they aint striaght.
"HOLD ON TIGHT"
they lean in at the top right?
yotamckimboy4x4
yes. they lean at the top pushin the bottom out.
"HOLD ON TIGHT"
