10 and 12 bolt rears
Started by simmont, April 22, 2006, 05:07:19 PM
simmont
has anyone done this or seen it done.  tyring to figure out what to do with the  front rear 10 bolt.  to mount it need to move springs out or cut in to the diff.  what is the easy and most effective way to do it.  if cutting diff don't think i  will be able to get u bolts around it to hold it together.help please :dunno: :help: :hammerhead:
89 Single cab, ground up build starting now.
2014 1794 Tundra Crew Max Daily Driver "work truck".
SOLD:85 REG CAB 22R FULL WIDTH 38'S DUAL CASES CUSTOM FRONT WINCH BUMPER CUSTOM CAGE HYDRO ASSIST LOCK ALL AROUND.
SOLD:DALIY DRIVER : 85 RUNNER 22RE 4" LIFT 33"x12.5x15  HI STEER DIFF ARMOR TRUSSED DUAL CASES LOCKED ALL AROUND.
IronClad
outboard the front springs  dont run the 10bolt rear   run the 12bolt and just redo the perches on the axle.  the front you need the outboard the springs. dont be an idiot and start cutting into the pumpkin. theres a few around here like that and it makes the axle garbage.
Annihilation  Fabrication
Do you need a Hammer?
simmont
yeah didn't want to cut into the diff.  got any pic of any rigs that have been out boarded.  have the 12 bolt in the rear for the truck 10 bolts going up front.  toy spring are 26.5 in. inside to inside the 10 bolt is 29 in. inside the perches.  help thanks
whiteman
I would move the perches in as far as possible without out cutting into the pumpkin, and then out board your springs to mach that width.   The farther in the springs are mounted on the axle = more leverage which = more flex.  I would not waste my time with a 10 bolt or a 12 bolt though, seen to many granade to have any trust in one, and they are not worth the money to build.  I would put money on a stock toy, before a 10 or 12 bolt.  :twocents:
simmont
stock toy rears aren't wide enough to run 39.5x15x15swamper's and 60 are to wide for where i go.  so 1/2 ton Chevy rears are the only real option.
whiteman
Quote from: simmont on April 24, 2006, 01:04:10 PM
I know of alot of people running 40"+ tires with toy rears, so that is not a problem.  I am pretty sure a dana 60 is just about as wide as a 12 bolt, considering they are both full width axles.
IronClad
guess my 12 bolt is garbage.. :shake:   12bolts will stand up to 40s and bigger in a toyota.  toyota axles just arent wide enough to run a tall tire.. they are strong enough but if you wana use the tire to its full potential..    fullwidth is the way to go.
red
a dana 60 is the same width as a gm 10-12 bolt, or a gm 14 bolt (the best option)
10 bolts do grenade with a v8 easily, but i havent heard as many bad things about the 12 bolts. the 14 bolt is very strong, far superior to the 10-12, and slightly stronger than the dana 60.
read and comment :whip:
USAF EOD tech
simmont
anyone out there got any pics of out boarding there spring.  like to see pics for reference before I start mine. thanks
Truggy
Building the CRUISER
Truggy
Its got a double drop box up front the first on i did and this one which was made to fit the D60. and in the back i just built some mounts as well and put the shackle on the bottom of the frame for some lift and more flex. :beer:
whiteman
:yikes:   Damn!!!  that has got to flex sweetly.
Truggy
oh yeas it did.  :yupyup:
simmont
what size shocks do you have up front
