86 TURBO 4X4 SHORTBED
Started by nshankel, April 22, 2006, 11:30:00 AM
nshankel
86 Factory Turbo truck short bed
$7000 or best offer
Good running truck registered non-op in CA
Needs smog
I built the truck while i was working at Pro-Gear in san diego, I used it for about a year, then i got full size.
located in san diego, i have a trialer and can deliver.
THIS TRUCK HAS 210.6:1 CRAWL AND WILL GO AS FAST AS YOU WANT ON THE HIGHWAY!
Strong running 22-ret engine with approximatly 30k on rebuilt shortblock
and 10k on rebuilt cyl. head.
engine and driveline
-L C engineering valve springs, camshaft (smog legal) and adjustable
timeing gear.
-block decked with no head shim installed
-new OEM timeing chain, follower and oil pump
-TEC TB-20 turbo upgrade (capable of 28 psi., currently set at 7 psi.
this turbo has no lube or drain back problems.)
-3" exhaust with flowmaster muffler and 3" high flow catilytic coverter.
-HKS turbo timer (for cool down)
-HKS PFC F-CON fuel controller (piggyback computer to supply extra fuel under
increased boost conditions)
-carbon fiber clutch
-rebuilt transmission (with OEM synchro rings)
-Marlin Crawler Ultimate crawler T/C with 4.70 gears.
-stock T/C
-driveshafts with new u-joints and balanced
-4.56 Detriot Locker Turbo rear differential with new bearings
-4.56 Lockrigth front differential
-Bilstien shocks
-Braided SS brake lines
-32 11.50 BFG M/T tires with full size spare on OEM heavy duty
steel wheels
body and interior
-factory analog dash
-Autometer boost, water temp., rich/lean gauge (white faces to match dash)
-grey 4-runner seats
-black CAN-BACK top
-hella H-4 headlights
-body is white with no major dents but does have some rust
(normal toyota places)
spares and extra parts (from donor truck)
-Turbo 5-spd and T/C (cores in good condition)
-flywheel
-engine block
-original replacement turbo, rebuilt, in good condition
-oEM computer
-air flowmeter
-everything needed for A/C coversion
-driveshafts
-lots small parts (pullys, bolts, sensors, brakets)
thanks for looking
8D3TOY
willing to part with the spare trans & T- case? I am in south orange county CA
