dual Tcases in 94 pu
Started by lizard, November 30, 2003, 05:14:06 PM
lizard
Will a dual case setup fit into a stock interior,I'am just curious if the second shifter will clear the seats in this year 90-95.
If someones done it could yah post a pic?
 I read that I may need a speedo attachment also , is that correct?
  any other extra  problems/parts I need to know or fab?
stock 94 22re
84runner
If you buy the hole kit The only thing you will have to do is cut the hole in the floor get your drive lines and put it in. It will come with everything else. If you have buckets theres no problem, if you have a bench you might need the shifter made depending on how you sit in the truck.  But when it comes time you call marlin and they will set you up with everything you need to do it right the first time.
