Actual tire height
Started by Taildragon, April 15, 2006, 01:06:32 PM
Taildragon
I have 36" tsl/sx swampers, they fit great and was wonderin if 37" mtr would fit, height wise.  If someone has measured the height at say 30psi from the top of the tire to the street I would like to know.  Thanks
KYOTA
lilbuddys got them he'll hook you up. I'm sure they will fit and would be surprised if they were 36"
lilbuddy
Quote from: KYOTA on April 15, 2006, 01:10:05 PM
If I can find a tape measure I will go out and measure in just a bit.
When I got them they were only 36 5/8" brand new. Now they are about 65% tread. Ill go check it out.
RIP Kyota.... you are the man
GET IT!!!
IronClad
mine right now  were shorter than a set of brand new 315/75r/16's  BFG MT's   on my dads ford :(  but yeah  MT/rs  brand new measure roughly 36 and 3/4ish depending  on the vehical
Annihilation  Fabrication
Do you need a Hammer?
BCD
I've been in the same place as you, I originally had 36" swampers, and switched to 37" MTR's on the same wheels, and the MTR's were a little tighter than the old swampers with a little rubbing in the back which I never had before. It surprised me because I was always under the impression that swampers measured more true than MTR's so I thought that the MTR's would be effectively the same height as the swampers but no such luck, had to do some fender trimming. So while I don't have the measurements I will say the MTR's were a noticably taller, you'll love them!
bmxanddie
bran new mtr's and bran new 36 tsls are pretty dang close in size. the swamper is pretty much a 37:)
Yup, my measurements are consistent with the above ones.. When Marlin got his 37" MTRs new, I measured them to be about 36-13/16" or 36-7/8"
Shamb
37" MTRS are equivelent to 36" SXs give or take a 1/4"
I have a picture of my 37's next to a buddies 36's somewere.
