Formula Toyota Series
Started by BigMike, November 25, 2003, 10:46:50 PM
Wondering if anyone was going to enter into this new event.
http://www.formulatoy.com/
It is pretty awesome and will be highly competitive for the average 4x4 builder.
Here is a list of the rules and regulations as to how the Truck must be built:
Engine
Only Toyota 20r, 21ru , or 22r engines are allowed
Must use factory head - for block
Must use stock carburetor
Must use stock intake manifold
Must use pump gasoline
No propane
Must be naturally aspirated
Radiator must mount in front of engine
Electric fans allowed
Engine can be moved back 0"- 8" from stock
Engine can be moved down 0" - 1" from stock
Transmission / Transfer case
Any Toyota make or model manual or automatic transmission
Any Toyota gear driven mini truck case or combination of cases
Any manufactures gear set.
Any gear ratio
Dual case adapter adapter must be commercially available
Cage / Chassis / Body
Safety cage built by an approved vendor
Frame must be Toyota Pickup or 4Runner frame, 2wd or 4wd
Steering
Any manual or power steering box.
Box must be attached to main frame rail
Drag link must attach to pitman arm on steering box
Ram assist steering is allowed
Any aftermarket high/cross over steer kit allowed.
Steering must attach to stock steering arm location using the stock method
Front axle
Front axle must be from 1979 - 1985 Toyota Pickup or 4Runner
Aftermarket birfields allowed
Aftermarket inner axles allowed
Any Toyota 8" third member allowed (FJ80, V6 or 4cyl)
4:10 ring gear only
Must use oem Toyota Pickup/4Runner knuckles
Differential shaving allowed
Trussing and diff armored allowed
Birfield eliminator kits not allowed
Rear axle
Rear axle must be from 1979 - 1995 Toyota Pickup or 4Runner
4:10 ring gear only
U-bolt flip allowed
Aftermarket axles allowed
Lockers
Any aftermarket locker
Open or welded differential allowed
Front suspension
Any conventional 1/2 elliptical leaf spring allowed
Attachment methods must be oem style, fixed at one end and a single shackle at the other end
Any aftermarket steel non take apart shock.
Shock must attach to axle in oem fashion
No traction bar or link type attachments
Springs must be mounted so they are stock width apart
U-bolt flip allowed
Rear Suspension
Attachment methods must be oem style. fixed at one end and a single shackle at the other end
Frenched spring hangers allowed
Inboarding of springs allowed
Springs must be mounded no closer together than front stock spring width
Single traction bar allowed
U-bolt flip allowed
Brakes
Any year Toyota front disc
Any year Toyota rear drum
No cutting or turning brakes
Functional parking brake or micro lock
Battery
Any spill proof style battery
Battery must be securely mounted, no bungee cords
Tires
Any tire
Any wheel
Internal or external beadlocked wheels permitted
Fuel system
Stock tank or fuel cell
Fuel system must either be closed loop system or spill proof roll over valve.
Vehicles that leak fuel will not be allowed to continue with competition until the issue is fixed.
Safety
D.O.T. approved helmet
One piece fire restraint driving suit
Four point seat harness
Window net
Metal roof must cover entire roof opening
Solid metal roof can be bolt on at least every 12" inches
Expanded metal roof must be welded at each contact point
First aid kit
Fire extinguisher
84runner
Sounds pretty awsome except the frame cannot be self fabricated.  But there is reasoning behind that I bet.
It sounds super cool and keeps it down on a closed budget. If I had more time and money I would definitely build one...
tarabull4x4
I think this will be great for people who want to compete without having to compete with other peoples money!!! I have a friend who is doing this who previously was competing with his x-cab toy. I kind of like to compare it to nascar where it is about the driver and in this case the spotter also! Good luck to all that compete.
freds40
Yeah I have a buddy in Oakhurst with lucky #13 chassis. He just got it and is trying to get it ready. It was about time since his latest X-Cab was getting thrashed.......again  :_order:
"between projects"
gferris5
Did I catch that you can't go lower than 4.10 dif gears? It's all made up for in t-case gears but it doesn't seem like people run 4.10s in built rigs-good for strength though. It makes sense, it's just interesting...
freds40
I was talking with my buddy about the rules and stuff and we figured that for a comp atmosphere, you don't want extreme low gearing because it is a race against the clock. You can get plenty of gearing out of the cases and have a stronger drivetrain by running 4.10s. This will cut down on the time needed to drag the fool off the course running 5.71s and slowing the competition down. He has duals with a 4.7 in the rear but he said that in his full bodied comps, he only engaged the front case maybe a total of 2 times so he's thinking of running just dual stock cases. Much different mind set when you're running for time than when you're just f'ing around on the trail!  :driving:
"between projects"
moutaintoys
I just went over the rules it says nothing about drive line dis or marlins new case
Lets go break somethin "GO NAVY"
mr4x42u
Thats because the rules were made befor the case idea was out in the know..I'm sure as the case becomes ready for the market there will be somthing in the rules..
moutaintoys
thay say there running us on the stock corse but if you cant turn your just out there nocking over cones
Dick Foster
That is a very strange list of requirements.  Maybe it should be called formula early toy
zags
Quote from: moutaintoys on December 11, 2003, 06:56:50 PM
No, it was considered. That is why this rule is in there:
Without those, the disconnect is useless.
