Smog/Header Issue
Started by 95TacoTruck, November 18, 2003, 10:40:59 AM
95TacoTruck
Just wondering how everyone else dealt with this problem.  I have a smog legal header from LC with the carb# and all legal like.   I was told I still have to have the pre- heater hose attached to my air cleaner to pass.  I saw the contraption that downey sells to attach it to a header and I made my own.   I am just curious what anybody else knows about this, been told, ideas, I am hoping that he will accept it.  Thursday is dooms day at the local test only shop.
95 Tacoma Extra cab, many mods to come........
84runner
Well that don't make much sense if the header is carb legal. Can u still attach your heat shield around the header?
Ferg
Air cleaner pre-heater is just that, heat incomming air for increased 'efficiency'.  Smog man will accept just about any attempt at having one.  Only issue with a header is that end of tube attached to header tubing should be smaller (restricted) so as to actually collect heat and not be just an air tube.  Should be attached in such a way so that it looks 'tee-d' to the header tube.
Any questions feel free to call same area code 583-1471
95TacoTruck
I notched a half moon shape in the tube attaching to the header so it sits flush on there and a hose clamp holds it tight.  If it were painted it almost could pass for being made that way.    :_oops:   :idea: I think I did a pretty good job if I do say so myself for using Aircraft Shears and a file.   lol   Also someone asked if I could attach a the heat shield and that is a negative that is my whole problem.  I could weld on a bracket but it would ruin my ceramic coating.  I'm gonna give this a try
hawaii500_1999
i just hack sawed a piece of cyclone fench post off and tin snipped two tabs and bent them out then hose clamped it on the header and clamped the tube onto that.
passed
1985 4runner on 35 boggers.  22re, W56 tranny, daul cases with 4:1 in the back case, ford f150 fronts with 63" chevys in the back, cross over steering, full width chevy axles with detroit back and ARB front,
84runner
95TacoTruck
The smog guy made no mention of it even though he was an ass about other stuff so I must have did a decent job
