you have the L43 tranny, aluminum 4 speed??
Transfer Case Shifter installed backwards.1. unbolt shifter2. turn shifter 180 degrees3. remount shifter
Quote from: 79Coyotefrg on Mar 23, 2006, 01:09:28 PMyou have the L43 tranny, aluminum 4 speed??um is that what was in the 85??? if so yes. i was told a 85 drive train is in my truck
um ok is the tcase shifted from the rear part of the tranny ?? must be a G54its a all alum housing
yep, if its a alum housing its a forward shift, most likelycall marlin and get a shifter socket and seat, thats why its so sloppy
Quote from: GoaT on Mar 23, 2006, 01:37:04 PMQuote from: 79Coyotefrg on Mar 23, 2006, 01:09:28 PMyou have the L43 tranny, aluminum 4 speed??um is that what was in the 85??? if so yes. i was told a 85 drive train is in my truckIf you have 1985 drivetrain then it is a W56 transmission with a RF1A top shifting transfer case.
Goat, go pull your boot and see if the tcase shifts from the top of the tcase or if theres a little metal plate there and the shifter goes in the trannyi'll bet its a forward shift
its a G54
Started by RogueDogg General 4WD Discussion
Started by bloc Engine
Started by hazmat888 Newbie Questions
Started by THEMAN Toyota Pickup/4Runner Tech 1979-95
Started by Chevota22 New Member Check-In!
