BB's and Golfballs Back from the Dead.
Started by Rock_Starr, November 02, 2003, 09:49:18 PM
Rock_Starr
I am after some estimations or factual quanities of golf balls needed to get 37 boggers to behave. At freeway speeds.
I have three lbs of BBs evenly distibuted between four tires.  about a quarter cup a tire.  I think that this may be toooo much. When i go over bumps (sometimes not always) i get an ossilation started that must be from some sort of a wave in the BBs or shift in them. It only will happen at speeds over 50 mph.
Anyone have similar issues?
Im am thinking less BBs (weight)
And I am also thinking that the larger diameter of golf balls may be the solution.
Free wisdom for all:
"Spend your beer money on yourself, sex with strangers is often weird and uncomfortable, marriage ruins everything, and oh yeah, Gatorade is delicious."
gferris5
Hey dude
Pirates just had a thread on this-as usual not much got done.  some people seemed pretty happy with their golf balls, some people warned about the impact of a foreign object on the inside of the tire. I think it was under the 'general 4x4' heading over there too. with any luck, some of the dudes on this board will have some advice as well. good luck
mr4x42u
yup..I had the same problem with bb's and boggers..I went with gold balls..They seemed to work..I went with 3-5 depending and it seemed to take care of things..Its hard to say how many because each tire is differend..I was able to put mine on a balancer at work and just added the amount of weight needed in golf balls..
Rock_Starr
Thanks Mister 4x4.  one up for you.
Nice Rig Ferrits.
not exact measurement but I use the middle part of a rattle can lid always done the trick and I havent had an issue like that.
WT
SeaBass44
I run balls, golf balls......I weighed them, if I remember 2.5oz per, I run 6 in each 16/35 bogger, they balance fine, of course they are still heavy out_a_round bias ply tires so I still get the slight wobble at 30 or so, no big deal. I run these on 15x8 2" BS on a 80 SB
