Author Topic: What's this Flange off of???  (Read 2121 times)
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,413
  • Member since Oct '04
  • Proud Parent
« on: Mar 19, 2006, 06:32:17 PM »
Pulled my flange off today and I can't figure out what this came off of.. i'm sure I knew at one point and time but can't recall.. I mated it up against a flange for a 83' Toyota pickup, 85 Toyota pickup and 92 Toyota 4runner and came up blank so i'm hoping someone will recognize it and tell me so I can get a new one.
The rear flange bolt pattern for Toyota seems to be 2 3/8" x 2 3/8"   but the one I have is 2 3/8" x 2 11/16"
Here's a shot of it, any input would be appriciated as always.
  • Turtle Points: 1425
  • Male Posts: 22,629
  • Solid axle Toys Rule ! ! !
Re: What's this Flange off of???
« Reply #1 on: Mar 19, 2006, 06:38:02 PM »
looks like the front output of a early tcase
« Reply #2 on: Mar 19, 2006, 06:39:05 PM »
yep  off the 83 :yesnod:
Shamb [OP]
  • Male Posts: 3,413
  • Proud Parent
« Reply #3 on: Mar 19, 2006, 06:46:18 PM »
wouldn't the rear and front bolt pattern be the same?   I just bought an 83' rear flange from KYOTA and its a diff. bolt pattern.
This flange you are looking at came off the rear output shaft.
« Reply #4 on: Mar 19, 2006, 06:49:35 PM »
if you knew where it came from why did you ask :slap:
but i know my front output flange looks the same
as far as the pattern,  alot have the kinda offset , like rectangular pattern
Shamb [OP]
  • Male Posts: 3,413
  • Proud Parent
« Reply #5 on: Mar 19, 2006, 06:54:05 PM »
Quote
That's the thing.. IF I knew where it came from I wouldn't have asked.. I just know what it seems like it DIDN'T come off of. I would figure if it came off an 83' like you said.. then the 83' rear flange I bought should fit. I suppose I could be wrong but i'd suspect that the front and rear bolt pattern would be the same.. possibly not?
All I know is if I pull a rear output flange off an 83' , 85' , or 92'  its not going to bolt up to the driverline sooooooo... gotta find out where this flange came off of so I can get another   :hammer:   :hammerhead:
« Reply #6 on: Mar 19, 2006, 07:00:06 PM »
well i have a few different flanges,   but the rear outputs are almost always round, thats the weird shape of a early front flange
i can get you pics if you need them
Ramrod
  • smelling like vag and loving it
  • Turtle Points: -59
  • Male Posts: 3,600
  • Member since Jan '05
  • fully bodied & Fully getting it
« Reply #7 on: Mar 19, 2006, 07:06:09 PM »
the front flange is different because it has a cv.  the back one is supposed to be round on your truck.  I got a couple I could take pictures of in the morning
Shamb [OP]
  • Male Posts: 3,413
  • Proud Parent
« Reply #8 on: Mar 19, 2006, 07:08:35 PM »
when you brought that to my attention about it being a front flange I scratched my head and said ".. hmm.. that sounds about right"
because the rear's are always round and the fronts are that odd shape. but why in the heck would they make the rear flange bolt hole pattern diff. from the front?  im just curious..
if i can just figure out where this came from and get another one that's all that matters  :)
Ramrod
  • Male Posts: 3,600
« Reply #9 on: Mar 19, 2006, 07:12:57 PM »
how big are the bolt holes?  a 84 and newer will have bigger than the older ones
Shamb [OP]
  • Male Posts: 3,413
  • Proud Parent
« Reply #10 on: Mar 19, 2006, 07:16:55 PM »
umm... like 1/2"  or the equivelent to metric... the bolt head's are 13mm
take a picture of the front and shoot it my way. I bet that's what it is.. because your right... I did a cv on my rear driveline because of the angle.
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Member since Feb '05
  • Annihilation Fabrication
« Reply #11 on: Mar 19, 2006, 07:20:50 PM »
yeaahh its off a early tcase...  i have one on a tcase sittin in my yard
Do you need a Hammer?
« Reply #12 on: Mar 19, 2006, 07:32:30 PM »
my 79  came with like 8mm  bolts, 12mm head with 14mm nuts , but they made alot of drivelines with smaller bolts,
but converting to the 10mm bolts now  :woohoo:
KYOTA
  • Turtle Points: 1759
  • Member since Jan '04
  • Wreckin Ball '09
« Reply #13 on: Mar 19, 2006, 07:53:43 PM »
just double drill that flange you got from me
Shamb [OP]
  • Male Posts: 3,413
  • Proud Parent
« Reply #14 on: Mar 19, 2006, 07:56:46 PM »
yea........... i thought about it but i dunno how close the holes are going to be to the edge.... making it weak .. and you know  :blah:
Last post Aug 15, 2006, 07:37:08 PM
by toyoder
Last post Sep 16, 2006, 06:31:24 AM
by fullthrottle
Last post Sep 10, 2008, 05:36:28 PM
by fordh8r
Last post Jan 24, 2009, 08:38:24 PM
by 86bobbedtoy
Last post Jan 02, 2010, 10:18:08 AM
by Phazertwo
