Got My Snorkel
Started by toxic, March 12, 2006, 06:55:01 PM
toxic
No going back
Need to plumb it to the air box/move coil and seal off all elc plugs( had to do front brakes first so didn't have time to plumb it after I got it on)
You Build It/You Drive It/You Break It/You Fix It...Who Cares...It's all part of Wheelin
86 4Runner
32 BFG MT'S/NeilFab Sliders/Arb Snorkel/Hand Throttle/
RustyToy
did you put in a disconect for everyday driving?
toxic
Quote from: RustyToy on March 12, 2006, 07:27:12 PM
Why would I need to do that?
86 4Runner
Quote from: toxic on March 12, 2006, 08:00:48 PM
I second that thought...... why would you need a disconnect?
I have a friend that has one and runs it 24/7 on a DD.
BoMXtreme
Its aimed towards the front, i think your good for dd.  If it was aimed backwards youd need a disconnect so you could get airflow at freeway speeds.  8)
Looking for 35s in SLO later summer time, like august.  Swapping Tires??
RustyToy
I'm not all knowing snorkel guy or anything, but i've herd that its like breathing thru a straw for your motor. so a quick connect diconect would help ya on everyday level.    :hammerhead:  I was thinking about putting one on, but I would only use it a dozen or so times a year.
Hasn't affected his performance at all.
Wermz84
Think of it as a "Cold Air Intake"  for your Yota!
By the way looks good.  :thumbs:  Where did you get it?  And post some pics of under the hood when y0u plumb it to the air box. thanx.
I like to Drive!
toxic
Quote from: RustyToy on March 13, 2006, 07:48:09 AM
the Snorkel has a much bigger opening then the stock hose( 2in) verse that big inlet ..Will get a lot more air to motor after hookin it up..I am going to plumb it tomorrow so I will post pics cause it does not come with anything to do it so its fab time
86 4Runner
toxic
Quote from: Wermz84 on March 13, 2006, 09:38:26 AM
I got it at  http://www.rubiconusa.com/store/products.asp?folderid=649 cheaps place I found for Snorkels
86 4Runner
RustyToy
cool, i'll be getin one then now. Looks good.
