project, 1jz swap, 87 4 runner on 40's, possible sas
Started by crizor2001, March 09, 2006, 12:17:31 PM
crizor2001
i need some help making sure i have what i need to do the enginge swap.IS the 22r bellhousing the same patern as the 1jz,  how much power can the stock tranny take,   any help please
thanks chris
hudlenutz
...might need to check the supracharged site for this one, but I'm pretty sure the 1jz bell matches up to either the w-56 or the R-151, but I'm pretty sure it's the R.
but that means you could match an R tranny to the TWO JZ motor.. hmmm...
For strength, it really depends on how you like to use the power.  For a ballpark, I'd say less than 250hp for the W-56, and less than 350hp for the R-151.
lilbuddy
Oohhhh I think I am going to like this buildup. Im keeping an eye on this one.
RIP Kyota.... you are the man
GET IT!!!
crizor2001
WHERE DO I LOOK TO FIND WHICH TRANNY IT IS?   THE PLAN IS TO HAVE A JDM 1JZGTTE KEEP IT MOSTLY STOCK WHICH MEANS ABOUT 220 HP. BUT GOBBS OF TORQUE. THW 2JZ HAS A DIFFERENT BELLHOUSING THAN THE 1JZ
hudlenutz
The block side of each bellhousing should be the same, but the tranny side is different.  The 1J bell was used as a crossover from the M series motor, so some of the older trans will fit.
If you want to run the 1/2 J series block with a manual transmission, here's the options from weakest to strongest:
N/A 2JZ bell will accept 4cyl NA truck transmissions, ie W-56 and maybe W-59?.
The 1J bell will accept R series transmissions (R150/R151), but the input is a little short, so you have to swap out the input shaft with a 2wd (R154?) or customize the bell.
Finally, you could use the 6 spd 2jz tranny and go divorced t-case.
You might have some luck over on http://www.supracharged.com.  Check out their forum.  Be forewarned, however, they'll try to steer you away from the 1J to the 2J or the 7M, which is not necessarily a bad thing.
