Where do I get an alternator!
Started by 95TacoTruck, October 17, 2003, 07:15:13 AM
95TacoTruck
I need a good alternator.  I want on made for an 85 Toy that is reliable and doesn't cost 500 dollars ala powermaster.   Does anyone know where to get one and what brand.  I know pep boys and kragens is out I was thinking NAPA or Electric Labratories.  ??????
95 Tacoma Extra cab, many mods to come........
Rock_Starr
Just get one with a warranty (Lifetime or better, ha ha).
They all will fail, I do however recomend Napa. And above all avoid rewound alts as they are expensive, carry short warranties and are prone to over-heating and cooking themselves. I if you want bigger amps i would recomend the a chevy CS130 series they can be had with a very similar body size and mounting patern.  (Same bolts as stock Toyota, thread pitch and everything)
R.S.
Free wisdom for all:
"Spend your beer money on yourself, sex with strangers is often weird and uncomfortable, marriage ruins everything, and oh yeah, Gatorade is delicious."
95TacoTruck
I was considering getting a bosch is the napa one better????
mr4x42u
I would go napa over any other stor bought brand..Like rock star saod the gm alt is the best upgrade due to amprage and cost difference..
ill bet the part# is 213-4711 for 3 year and 13-4711 for lifetime
that is off of just about any chev truck around past 88 so I think thats what ya need and if I remember right it is a 130? amp
so the cs130 will bolt up in the stock location???? :dunno:
what about wiring, i have the external regulator???
my buddies dad has a 94 yota that just lost his alternator and instead of spending 120+ I sold him a standard 65 amp chev alt. part#213-4011 and a pigtail to hook it up he said it works great and all he had to do was shim the bottom mount and modify the upper adjustable mount.  by the way its on a 22re
Rock_Starr
Ok, Here is some more info on the alt swap.
The GM CS series has a smaller body very similar to the toyota. The CS 105  (i think) has the largest amperage output  with a mounting method similar to toyota.  It is however serpintine belt driven and the pulley will need to be switched to a vee belt type and spaced out from the alt body.  the tension adjustment on the bracket will need to be modified to allow for the differnces in arc between the delco and nipon. The cs series can be run with two wires (output and field switch) bypassing the factory external regulator(pre 84?).
If you have specific questions or want to do this swap email me and ill get you more details and some rock solid info on what alt to ask for at the parts counter.
-Peace in the middle east
R.S.
tell me what i need to know o savvy one :bowdown: :bowdown:
95TacoTruck
Thanks for all the info I went to napa and got one it is doing the job and has a lifetime warranty!  :crossed:
Rock_Starr
Toy boy is it a Chevy or Toyota Alt?
Ill get that info for you all sooooon.
95TacoTruck
This one is all toyota...It has a lifetime warranty and they are easy to change so if it goes out i'll keep replacing them.   A chevy alternator would be fine and dandy but I like things to be simple and easy.
