Bad steering pump & Death Wobble?
Started by BLUCRUZ, March 07, 2006, 05:40:32 PM
BLUCRUZ
Could that be a possible cause? Ever since my steering pump spit off the belt and started making noise late last fall, the wobble has been getting worse. Wheel bearings are fine, trunion bearings are fine, preloads are all within spec. (front end completely rebuilt last spring) Rod ends are new, Tires are balanced and the the toe has been set in about 1/4" and still have lots of wabble between 40-50mph. I'm stumped. Could the pump be pulsing and causing the wobble?  :screwy:
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
IronClad
try 1/8th on the toe in  and check your shackle bushings aswell as ubolts
Annihilation  Fabrication
Do you need a Hammer?
BLUCRUZ
I think the housing is bent :sad2: 4* caster on the pass side & 8* on the drivers side. Alignment shop won't touch it because of that. They advised me not to drive it at all. Tough titty! daily driver.
alwayzbroken
Worn steering stabilizers have been known to contribute to death wobble.
BLUCRUZ
Quote from: alwayzbroken on March 08, 2006, 01:35:52 PM
What steering stabilizer? They only mask the problems in your front end.
alwayzbroken
Quote from: BLUCRUZ on March 08, 2006, 03:06:51 PM
True. Maybe you should put one on.
IronClad
time for a new housing then budday :( pretty normal for toyota  stuff.. thats why i went to GM.. i can actually not have to worry about alignment .. or bending a housing.. ...   maybe stick a steering stab on it till you can find a housing ?
