36'S VS DRIVETRAIN--YOUR OPINION/EXPERIENCE
Started by UGLYTOY, March 01, 2006, 09:15:08 AM
UGLYTOY
I'm getting new tires in a couple weeks for mine, will either be 33x12.50x15 tsl's or 36x12.50x15 tsl's.  There's only about an inch difference in height at the pumpkin, but more weight/leverage, etc.
I have a marlin crawler (2.28*2 only), 5.29's and 27 spline longfields w/fr and rr lockers, stock 22re and tranny.  Most trails around here are ruts/hills/mud, very little rock and what little rock we have is usually greasy.  When the trails are dry, they do give enough traction to break stuff when stupid.
I have broken 2 stock birfields w/33" mtr's, which rarely give very much traction around here (I cuss them at least once each trailride).  Also note that the birfields were broken before I added the marlin crawler.
What's your opinion--think it'll hold up to 36's, or should I just stick w/33's to lessen the breakage and have an inch less clearance under the diffs?
IronClad
ive seen  toyota axles stand up to 42" tsls and 40" boggers...  run them.. but check your steering stops  thats one of the main killer of a birf
Annihilation  Fabrication
Do you need a Hammer?
wadeky
skid
at least 36's.  Been very happy with 37" mtrs, locker/welded, longs, and dual cases with 4.7 gear set.  Only mechanical carnage was a weak tranny that was already on it's way out
I don't see anything that will change breakage on yours going from 33's to 36's.
Diggin a hole with plastic
90 ext cab toy, short 40 Iroks, detroit and diamond, mco8-r10 duals with twin stick, 4.7 gears and 30 spline Longs/hub gears-studs
SWAMPER
mudmaster
Time to go wheelin!
Run them.  Remember to check the steering stops and the steering arms regularly, but that should be done anyway.
whiteman
Run them 36's, you should be fine,  I will be running 35" Boggers, aka (Axle Breakers), and I have a rev limiter for a reason... :greengrin:
yotee
definatly the 36's if not bigger. the 27 spline longs are the chromo set? if so just go with whatever YOU WANT. the 27's and 30's will hold up to more than you think. i have abused my 30's and can't break 'em.
mike
88wildrunner
dont mean to hijack the thread but i am gona be running the same stuff as this guy a know 5.29's 27 spline longfields aussie locked f/r with 36 tsl's what i want to know is will a stock 22re be able to cruise at 70 easly?
WANTED: SR5 power window door panels. will pay cash or trade for home brew square tube doors
Ramrod
I was running a tired stock 22r for a long time with 5:29s and 37" mtrs and it wasn't bad at all as long as you weren't going up hill or against the wind.  other than that I could cruise 70-75 all day.  Now I have a new motor about ready to start with the engnbldr 143 hp kit with efi conversion on top of that so I don't think i'll have anymore problems.  and definitly go with the 36" tsls if not the 38's you wont break those birfs those are what i have and beat the piss out of em
UGLYTOY
thanx for the replies--i didn't figure it would break too much w/a stock engine, but wanted some other opinions before i bought tires
furrballs95
how long do you guys think that stock birfs will last with 36" swamper SX's cause i def dont have the money right now to buy some better birfs, cause its all going for the SAS kit :smack:
95 Toyota p/u 3.0 v6. Marlin SAS with 5"springs, 30 spline bobby longs, and a welded V6 third in a trussed 85 front axle. 529's front and rear, Marlin rear kit with 5" springs, lockrite rear locker,  36"  IROCKS on 15x10 black rock crawlers, custom front and rear bumpers,
I have tried breaking my 30 splines with my 37's and welded front end, no such luck yet.  the 27 spline birfs are susppose to be the same strength.  it just just the 30 spline inner axle is stronger then the 27 spline.  but you shouldn't have problems with 36's.
88wildrunner
depends on how you wheel it, its fine on the street but if you start beetin it hard offroad they'll break, jus carry some spares till you can get the better birgs.
furrballs95
well if the one toyota front axle in still at the junkyard i was at a couple of weeks ago i'm just going to get the whole thing that way i will have some spare ones
Quote from: 88wildrunner on March 02, 2006, 09:48:26 PM
IronClad
Quote from: furrballs95 on March 02, 2006, 09:42:30 PM
wheeled a truck all last summer with 40" boggers on stock birfs that were the same ones that came in the truck from 1983..  still being ran till this day on 40" boggers.. id say 36" sx's will be fine
gotrocks
go 36's+  I run 37's on profields (not really any stronger that stock) and I haven't had a problem.  I'm running the same duals 2.28x2 with 5.29 and f/r lockers.  Love my tires wouldn't ever go smaller now.  I'm not sure what in the drivetrain will have a problem with those tires except for the birfs and you already said you have longs, so go for it
FatAzzRunner
Run the 36's.  I started out with 36" TSL bias plys and I didnt like the tires too much as far as chunking where we wheel but they hooked up and I since then have gone to 37" MTR's and I love em.
I beat on my rig fairly hard and have not broke a Long yet.  I have broken a 5.29 R&P though, but it had 2.5 HARD years on it.
GOod luck, post up your pics when you decide.
85 Runner, 5" All-Pro Extreme Lift, Complete Marlin T-Case with new TS 4.7 gears, Super Birfields(Longfields), 5:29's, Detroited front, Spooled rear, 36" TSL's, Bikini top.
Yes, Livin in Kansas sucks azz!!
lal357
go with the 36's or up I'm running them on stock birfs now and set the steering stops i beat the crap out of mine and no problems yet spooled rear locked front 4.88's
80yota 22r 32/36 weber,header,custom bed,4.88 spooled rear Aussie front ,63" chevies,cage,yada,yada
furrballs95
Ramrod
you can run anysize tire you want on the stock birf as long as you don't have  a front locker.  When you put one of them in there you shouldn't run anything over a 33 i'd say
whiteman
BBW,  We must wheel alike because I would have to agree, with a led foot they will go fast.
Unless you have Bobby Longs  :eyebrow:
yotaboy79
hell im running 36 tsl sx's duals 2.28x2 5.29s welded front and rear on stock birfs and innards and amazingly there still holding up i know that as soon as i get them in a bind they will pop but as long as you drive smart they will hold i do plan on upgrading to 30 spline longs in the future just dont have to coin right now
furrballs95
my buddy just snaped a stock one today he has 33" firestone mt's and a welded 4.10 v6 third so i'm not to shure how a welded on is going to hold up with 36"
John Dibble
here is my DD and it runs on 36's i never had a problem with the front end but thats because its open
John Dibble
whiteman
 :suprised:   Oooooohhhhh!
I am going to run a welded rear and a locked front with 35x14.50 boggers, I will tell you how it goes :yesnod:
FYI:  I am a sucker for Rev limiter - Nuetral drops  :gap:
Just Do It  :cool:
