Author Topic: 3" rear lift springs  (Read 1480 times)
RCKSQRL
  • Male Posts: 588
  • Member since Oct '02
  • Viva La Yota!
« on: Feb 21, 2006, 03:16:19 PM »
Ok-
I am looking for about a 3" lift spring for the rear, preferrably one that is a bit longer than stock with good flexability. I have a rocker perch that gives about 2 " lift, too much for the 5" springs I currently have sitting in the garage. Thoughts?
Can't seem to find a lot of info on this. Seem to recall Marlin selling a 3" lift spring a while ago however I didn't think I would need on at that time.....
Thanks in advance!
'85 EFI Runner
4.3 with 700R4- for sale
5.29 detroit F/R
Front 3 Link with air shocks
rear 4 Link
Custom Fuel cell
8274
Crawler #719, rear with 4.70 # 677,
Twin stick
Skys manufacturing T-case crossmember
6 point cage modified with harness bar, dash bar and PRP seats mounted to cage
2 feet chopped off the back
It seems it is never done........
in works for new body and exo, motor and trans swap...
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 3" rear lift springs
« Reply #1 on: Feb 21, 2006, 08:02:47 PM »
you can run some S10 springs  or take a leaf or two out of the 5 inch springs you have
RCKSQRL [OP]
  • Male Posts: 588
  • Viva La Yota!
« Reply #2 on: Feb 21, 2006, 10:29:46 PM »
I have thought about taking a few leaves out however  :help: is needed as I do not feel comfortable doing this untried myself.
'85 EFI Runner
5.29 detroit F/R
rear 4 Link
Custom Fuel cell
8274
Twin stick
« Reply #3 on: Feb 22, 2006, 08:19:16 AM »
you will need a good sized bench vice   ,  and a prybar and BFH
and a wrench to fit what ever size nut is on the tie bolt,    put the springs in the vice and remove the bolt, and any clamps that are around the springs, then remove one or 2 of the lower leafs,  then re install the bolt,  the vice will squeeze the pack back together
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Feb 22, 2006, 08:35:25 AM »
Don't worry it's easy, and if you don't have a bench vice I use 2 c-clamps to keep every thing straight. Plus to keep the center pin hole lined up as I pull the center pin out I simultaneously insert a stud or dowel to keep the leaves from moving around as I pull or insert leaves.
Last post Apr 07, 2006, 02:19:13 PM
by twerp
Last post Jul 26, 2006, 06:04:53 PM
by Broke_Okie_Ty
Last post Dec 09, 2006, 06:34:16 PM
by rockrawlerzuk
Last post Feb 05, 2008, 02:53:01 PM
by Goose
Last post Mar 07, 2008, 04:28:10 PM
by squirrel84
