Toyota Goes Boom
Started by seanc, February 20, 2006, 12:33:02 PM
seanc
carnage from this weekend:
anyone have a 4:10 third they want to sell?
You win some, you lose some.
blackdiamond
What were you doing to break a 4.10 Ring Gear?
What is wrong in the other picture?  It looks like some of the steering bolts might have broken?
seanc
the 4:10 third exploded due to the rear end being so loaded up the leaf spring bent. and yes the front 2 high steer bolt sheered right off in a recovery operation from the third exploding. if any one has a third, high steer studs or cone washers please pm me. thanks  :biggthumpup:
blackdiamond
Ok, your rear 3rd member self destructed, did it have a limited slip or locker installed?  The resulting release of force bent a rear leaf spring and in the process of recovery you were pulling on the steering?  Funny things happen when in recovery mode.
seanc
the rear is welded. while in a tight spot i attempted to back loading up the rear end and bending a leaf spring at the same time, i think the shock of backing up did the damage.
