it's a matter of yer truck bein able to be towed flat
The only problem i see is the runner having enough power to tow the truck up the hills. do you still have the dakota? how much can that tow?
Stopping coud be fun
I flat towed mine to moab a couple of times. Once with a 02 stroker and once with my fathers 01 4-runner. My truck weighs in at about 3000lbs. The runner had no problem pulling the hills or at freeway speed even stopping wasn't that big a deal. Just like pulling any other trailer you just need to give yourself some extra room to stop and pay attention. NOW THE WARNING........ Bb VERY cautious when TRYING to stop in the road is wet or braking while turning, ie mountain roads. When pulling with a tow bar remember that the truck (being towed) responds much slower to turns than a normal trailer. So while you are turning the truck is still headed straight and will want to push your rear end out. In general this is not too much a problem. But if it is wet, or you are going down hill too fast and brake going into a turn this can and will cause you to spin out with no good results.I have found that the heavier the tow vehicle the better when flat towing.Hope this helps.
I agree fully. Your Runner will pull the truck and will probably do okay even on hills (don't let the tranny go into overdrive on hills or even flat, you will kill the tranny) but just because it will pull it, doesn't mean you should. I've never been fond of towing a load that is within only a couple of hundred pounds of the towing vehicle when there are no trailer brakes. Not enough brakes are workable on the trails (I've done it) but on the road, you're not the only one that could get injured if you can't stop or your runner gets pushed around.
Hmmm... is there a way to run the brakes through the truck to the runner kinda like trailer brakes? Yer right, that could serve a problem on hills... flat would be fine
I towed a toyota truck home from chico with a tow dolly behind a beat ass 93 gmc sonoma with a v6 and it did fine.
No wait, he can't tow the truck on a trailer..it's TOO heavy .
Actually there is a 900# aluminum dual axle trailer with brakes on both axles. That would have me towing around 4200lbs. Still a lot though.
Started by jafish Toyota Pickup/4Runner Tech 1979-95
Started by jimbo74 Tow Rig and Trailers
Started by Xlerator Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by MiniSimp Project Research and Build-Ups
Started by Lowrider General 4WD Discussion
