On the Cheap= 5.29s or 4.56s w/dual trans??
Started by yoter, February 03, 2006, 08:48:28 AM
yoter
I have a 86 that I am wanting to run some 36x12.50s(or wide 35"s) I am kinda buiding on the cheap as I get some cash. I am wanting to change the gear ratio to turn the tires, and run a locker on the rear. I have a open V6 4.56 to put in the front(while I build my 84 axle) and a V6 3rd (4.10) that I could rebuild with bearings/seals and a locker. I also have 3 4cyl 8" 4.10s, that I could put 5.29s in. But I cant do both (5.29s/dual cases) right now. So its either 5.29s,locker- or- 4.56s,locker,dual trans?
I might drive this truck on the road 15-20 miles 15 days a month at the most. Its a weekend wheeler. I mostly play in the mud and climb hills, not much at rocks right now. But will the 36"s/4.56s eat my clutch drivin on the highway?
MiniSimp
yoter
No not a daily just might drive it some highway miles to get where Im going.
MiniSimp
synwars
Quote from: yoter on February 03, 2006, 08:48:28 AM
The only time you will be wearing it down should be on start off's from full stop. I have a buddy who runs 36's and 4.10's as a partially DD and he doesn't eat his clutch, just really slow at starting off the line.
"Don't let common sense stop you..."
Build up thread:
http://board.marlincrawler.com/index.php?topic=11425.0
KEEP IT CLEAN PEOPLE!!! :bat:
gturismo
#5
Most people, at some point, want to go to bigger tires.  So if you even THINK you might want to go bigger some day, then I would get 5.29s and the locker now.  Duals are great, but if you aren't crawling much, you can wait for those.
I think you'll be happy with the 5.29s and 36" tires. :twocents:
85 Runner
yotatilla
2 1986 4Runners+
1 solid Axle+
2 transfercases+
4 35x14.5 Thornbirds+
2 Aussie Lockers+
1 Marlin SAS kit=
UBER 4RUNNER
burnyota
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
AKDuramax
not but beat a dead dog but your best bet is 5.29s
83' toyota sr5 long bed 31x10.5 bfg mt's -under construction-
86' suzzuki samuri 33x14.5 boggers, 1.6 tracker spap, 4.62's locked trackuri axles, 4.1 transfer, exct.
02' chevy 2500HD duramax 35x12.5 mt's fabtec 6", edge box,k&n intake, mbrp 4" duals, exct.  :)
