Motor rebuild
Started by ksmith, February 02, 2006, 09:24:42 AM
ksmith
I have an 84 Toy with a 22-R/Propane, it's getting a little weak and is losing some oil and I was thinking about having it rebuilt with a little more power. What would be the best things to do, cam, heads, etc? Also, what do you think it would cost to have it done? I'm a college student and I'm on a budget, but do have a little bit of a stash built up to spend on it, so no LCEngineering motors, even though I've thought about it and it is tempting.
Thanks in advance.
Kane Smith
Make it or break it! (I usually break it)
KYOTA
 I just put propane on my 22R and love it! with propane you can up the compression quite a bit to get what your looking for. Have you talked to Cary at http://gotpropane.com/. that would be your best bet.
seanc
the thing that really holds the 22r back is the head design. getting flow out of a SOHC is difficult but doable, big valves, big ports anything the make the "big air pump" work better is good for power and efficency.
You win some, you lose some.
Quote from: seanc on February 02, 2006, 11:29:19 AM
This is exactly why people make hybrids!  The 20r head flows much better than the 22r head, hence unleashing more potential.
kyle_22r
let me correct that -- it doesn't flow more, it just flows "better".  the swirl ledge on the 22R ports actually helps with low end torque and efficiency but is one of the limiting factors in the design.
for low end power, i'd much prefer a stock 22R over my hybrid...but in freeway driving, it makes all the difference in the world!
:yesnod:   Amen brotha
a 20R ported heat with 22 valves is the best set up
Quote from: kyle_22r on February 03, 2006, 07:35:31 PM
What are you correcting kyle?
Nate  , maybe Kyle  was :boozer:  and thought he read it different :dunno:
Kane  how is your propane injected,  is it a carb like thing,  if so you can adapt it to fit a 20R intake,   you could buy a 20R  cheap  and steal everything from that 20 but the block,  have your block bored maybe .020  and use aisin /stock type pistons with moly or plasma rings,  20R head and intake and timing kit,  and cover  on the 22R block,  this way you'll have the best of both worlds,   big bore 22 block with the high flowing 20R head and double row 20R timing chain
burnyota
do the double row timing chains create more heat and noise? what about a single with metal guide?
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
i dont think the make as much noise cause the dont wear near as fast
what really makes the noise is a loose chain
kyle_22r
easy way to do the propane setup would be to buy an LC engineering 22R carb adapter for the 20R intake, then find a junkyard 22R carb and steal the throttle plate off of it :thumbs:
