I've got the Center Differential Lock in my 2001 4Runner and I don't see a need for Manual hubs.You've got 2wd normal, then hit the 4wd button on the transfer case stick and you have AWD, then hit the lock button on the dashboard (left of the steering column) and you've got true 4wd, then put it in 4low and you've got 4x4Low or put it in AWD Low.It would be a pain in the ass if you had to get out and lock and unlock the hubs every time you wanted to change your options.Currently I am loving the system, especially in snow.
So why have the 85?
thanks for the reply....my hilux got no button to push....only 2wdhi, 4wdhi and 4wdlow lever....so if i have understood well no differential in the center....i really don't know hoe Toyota can be so mess with so a lot car equal but with different name....i mean....the mine is hilux....but if you see the car you tell...this is a pickup!!is very difficult for me to understand wich are the parts in common between pickup 4 runner and hilux.....who can help me? i can provide detailed picture of the bottom....thanks againAndrea-klunk
so what your saying is, the push button is for like my sis driving in the rain or on slushy snow?? like awd but not for real 4wd
So you guys know:I've replaced a few transfercases in the trucks/4runners equipped with the pushbutton 2hi/4wd switch. The trucks equipped with the pushbutton DO have a center diff, and it'll burn up if used in an environment where the front and rear wheels DO spin at different speeds. FWIW, only use the stick and manually select 2wd or 4wd by moving the stick from 2HI to 4HI- don't use the pushbutton.These trucks have a silly electric actuator on the transfer case that controls things when the pushbutton is used. If that acuator is knocked out of adjustment by anything, the whole transfer case can be damaged and needs to be completely disassembled to investigate. There is a planetary gearset inside them that makes the magic happen, and is susceptible to damage if not fully locked into 4WD by using the stick.IF one desires to use the pushbutton, it should only be used on icy/snowy roads where theres no chance of enough traction to damage stuff if the wheels try to spin at different speeds.My $.02Ryan
Started by n.c.84 General 4WD Discussion
Started by KYOTA 1984-1988: How-To Guides
Started by blackdiamond General 4WD Discussion
Started by TheTank Parts For Sale
Started by Pygpen Parts For Sale
