why do you want to use the stock shackles? even if you move the hanger to use them, you would be limiting flex, the shorter shackle would bottom against the frame in a couple inches making the available flex of the spring useless. keep the longer shackles
what springs and length are those springs in the front? what length shackle in front?
take out some leafs then......
NWOR is retarded, i would buy from all-poo befroe them.......
well i guess that answers my flex limitation problem up front
47" is a 4" lift spring and the longer 47 1/2" is the 5" lift spring
Started by old school toy Toyota Pickup/4Runner Tech 1979-95
Started by *FFC* « 1 2 » General 4WD Discussion
Started by Volcom General 4WD Discussion
Started by mmessier2 Toyota Pickup/4Runner Tech 1979-95
Started by thomk172 Engine
