0 Members and 24 Guests are viewing this topic.
Wow, I'm really impressed! Looks beefy! good job. -Collier
It is looking great. Looking at that steering setup it seems like you will have your fair share of bumpsteer, see if you guys can tweak/bend draglink a little so it is more parallel to tierod. Also I hope that you have pushed that front axle forward at least 3" as it will make easy fit for those 35's, if not you can always chop some sheetmetal, that is what I have done with mine, since I have moved up to 35" tire as well. Looking at those smashed rocker panels, I would suggest that you maybe think abut cutting those out and just add some channel steel instead, it will give you all the strength you will need. and it will not rob any ground clearance. Just my $0.02.. Adem
she violated that poor amigo in stock form on the rubicon
if 37" [ro comps on 17" steelies weren't so heavy to work with I would pop them on her amigo and drive it around while she is in livermore.
It'll be a matter of gettin em online after that
with your internet connection that might take several days lol
so you have to have a hipinion?? is there room for a dual case ??
Good work FFC! Looking forward to seeing the updated photos without that variable tension cross member from the last pic. It has been alot of work so I bet your completly about the whole thing!!I never thought that I would ever say this about an Amigo, but I like the "ToyMiga" Next step, Mid mount that 575 crate engine like we talked about right.
rEdnECkwHeE1eR - I agree with you that it doesn't do a lot for steering geometry but it can help a little. In my case I have gone with SUA for front D44 and no flat knuckles as it will not work with my setup clearancewise. Long story short, I have had a lot of bumpsteer just by hitting potholes and what not, me and my bud decided to put a slight bend into draglink and make it more parallel with tierod as we could, not optimal but this is what we worked with. It does help, it will not cure bumpsteer alltogether but it doesn't feel as darty as it did before. Just my $0.02. One of these days I will get around to post some pics of my suspension setup, track bar and some other goods that are on there.
Maybe FreakyIsuzuChik or FreakyToymigochik? Driving around in that thing isn't gonna work for FFC.
Hey there's an idea paint it black and white camo, that way you could park in in a field anywhere and they'd think it was just a cow.
Nice level Stance!
Started by DTB General 4WD Discussion
Started by rmoore Toyota Pickup/4Runner Tech 1979-95
Started by Shamb Chit Chat Camp
Started by bng1 Parts Wanted
Started by Eschenfeldt New Member Check-In!
