0 Members and 14 Guests are viewing this topic.
We were able to use an IFS front driveshaft (I think it was a front) It works though
Wow that's pretty short. Won't be any room for a dual.
Yeah... I drove it today. I did the hydraulic to cable clutch swap and it works. I drove it a lil ways and it wobbles like crazy. The driveshaft I used for the rear won't work since we flipped it (put the cv at the pinion rather than the tcase). So now I"m in the market for another one that I can cut up
Yeah, I'm glad it worked and you got to drive it.. Actually she is going to run accordionized transfer cases (for flexibility) all the way back and bolt it directly to the axle flange..
Try putting the Dshaft how its supposed to be with the pinion pretty much pointed at the tcase.
I tried that to begin with. The CV side won't pull the angle from the tcase down. I turned the axle so that angle is almost zero. I guess a front '84-'85 driveshaft will do the trick.... anyone have one layin around?
is your pinion pointed properly ? a cv joint is probably not the answer. probably need a standard joint on each end since its so short..
Banks are mean, they'll gladly except your hard earned dollar and say they will keep it safe for you, but for some reason just can't find that deposit you made last week.
ok you have other problems then and a CV shaft isnt gonna solve your problems.. id really suggest having a regular ujoint shaft made. if done properly there will be 0 to very very little vibes.
eh hopefully ... i just hate cvs lol
Did you cruise through the Citrus Heights area the other day? I could have swore I saw a white sas'd migo with toyota axles a few days ago cruise by me. ... How many of those can their actually be out there?!
Where have I been....last I checked the 'migo was still a pile of parts...and now it RUNS!?!?!? I don't believe it. I demand pictures! Ryan
Ok, got the new driveshaft in today. Took care of the deathly vibrations that was goin on Left to do before MoonRocks: Bend floor so CV stops rubbing on itCover t-case with something (It's in the cab)Make shock hoops/install shocks for frontShorten front driveshaft 1/2" Bumpstops PACK!!!
Hey FFC, what day you leaving for moonrocks,im trying to leave the north bay late thursday night,be in Reno by dawn refuel body and truck and make my way to moonrocks.maybe we can caravan there.
wow this things really coming along and looking sweet. A couple questions though:Did you ever do anything with the rear springs or are you still running the big aluminum blocks? How is the low range with that t-case tranny combo? and dang I forgot the others but you need some rock sliders now
Started by DTB General 4WD Discussion
Started by rmoore Toyota Pickup/4Runner Tech 1979-95
Started by Shamb Chit Chat Camp
Started by bng1 Parts Wanted
Started by Eschenfeldt New Member Check-In!
