headers
Started by lockedyota, January 15, 2006, 03:52:11 PM
lockedyota
 :shocking: i just upgraded to a hedmann header . i'm getting an o2 sensor warning and a throttle body warning on the self diagnostis check. i replaced the exhaust system also but did not replace the cat. convertor would this make the o2 sensor go out.
Quote from: lockedyota on January 15, 2006, 03:52:11 PM
im guessing you got the header cause you wanted better flow,  if the cat is stopped up you aint gettin any flow
what size tube did you get??   hopefully at the very least 2"   with a stock engine, 2 1/4  is best
get a generic cat with a 2 1/4 in and out
lockedyota
i didn't put a cat back in yet cause the original was plugged,It's a 2" exhaust with a flowmaster muffler and headman headers. i was debating wether to adjust the afm a couple clicks thinking it may be running a little lean with the headers and exhaust.
AKDuramax
ahh just toss the cat! screw emissions!!
83' toyota sr5 long bed 31x10.5 bfg mt's -under construction-
86' suzzuki samuri 33x14.5 boggers, 1.6 tracker spap, 4.62's locked trackuri axles, 4.1 transfer, exct.
02' chevy 2500HD duramax 35x12.5 mt's fabtec 6", edge box,k&n intake, mbrp 4" duals, exct.  :)
whiteman
I have a downey header; when it was installed in my 4-runner it had straight 2 1/4" into a flow master and then 3" out, i really like the way it sounded, but I could have used a little more tail pipe, I only had 2ft.  No cat.
It ran fine for awhile but after I had the truck for about two or three months it started running really rich, it would load up all the time and even with all the windows rolled up you eyes would water up and you get this really funny feeling, almost like you were high.   I replaced the O2 sensor and it helped for like two days and then back to normal, I could not figure out what the rpoblem was.
You might start with the O2 sensor but you may need to investigate farther, I know that with the Downey header you have to purchase a universal o2 sensor and wire it in to the factory plug wire.  I cant use a factory toyota O2 sensor, that may of been my issue. :dunno:
